cylinder heads
Old Aug 18, 2019 | 03:13 PM
scrappie's Avatar
cylinder heads
Not too familiar with the 350 heads so which ones are best to worst?
Old Aug 18, 2019 | 03:17 PM
cutlassefi's Avatar
68-72, 5, 6, and 7a’s are all about equal
and good.
Old Aug 19, 2019 | 06:11 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The 3A are the worst. Big 75cc chamber, crack prone and the horrible "A" head exhaust port and a tiny 1.5" exhaust valve. The 8 heads just need a bowl hog on the exhaust side, already has 1.625" valve. After that they flow the same as the early heads. They work best with flat top pistons due their large 77 to 78CC(79CC factory spec) chamber.
Old Aug 19, 2019 | 08:12 AM
Kennybill's Avatar
Number 8's aren't anything to brag about either. #4's are good heads also.
Old Aug 19, 2019 | 05:52 PM
The #8 flow the same as early heads IF the lip is removed under the exhaust valve in the bowl. Any of the later #A heads need many hours with the grinder.
Old Aug 19, 2019 | 06:11 PM
coppercutlass's Avatar
Chevy budget Olds powered
Some of the earlier heads CC under 64 cc's I cc'd a set of #4's and they came in at 61 cc's
Old Aug 19, 2019 | 08:48 PM
Which is why the #4 heads are desirable. A 39 degree CBA and smaller chamber. They would give right around 9 to 1 on 73 to 80 350's.
Old Aug 19, 2019 | 09:16 PM
Inline's Avatar
Do you actually have any data to back this or just heresay?
Old Aug 20, 2019 | 09:43 AM
The only flow numbers I saw were for 7A heads, talking 135/120, horrible. The Mid Am numbers are inflated but were the same for the 4A heads that J+S flowed. Stock the 8 heads have very similar numbers to the 4A heads. Pull an exhaust valve on a 8 head and see what I mean about the lip. He said the #8 were a much better starting point than the 4A head. You would have to be blind, the 4A's exhaust is bad but looks better the 5A heads eyeballing it. Pretty sure the now absent Smitty said the same thing about the 8 heads as well and did flow tests.
Old Aug 20, 2019 | 10:01 PM
brownbomber77's Avatar
You talking about the 80's 307 7A heads? That would make more sense...
Anybody wanna start a Go Fund Me campaign for Mark to flow bench Oldsmobile heads with fresh valve jobs and 2.00/1.62 valves?? ha
Flow bench is nice BUT, in the case of LS engines, the lowest flowing cylinder head which came on all the trucks up until '07 (862/706) actually made the most power, unported, on 5.3 AND 6.0 engines.
Old Aug 21, 2019 | 04:32 AM
cutlassefi's Avatar
We flowed 7a’s, maybe this will help.
https://classicoldsmobile.com/forums...rmation-72789/
Old Aug 24, 2019 | 06:46 AM
Just shows that the 4A intake port is decent, looks better and flows slightly better than the 8 and probably even the early 350 heads. The problem is the exhaust port, very constipated and a tiny 1.5" valve. Yes, I meant the 7A 307 heads, flow numbers I saw posted were beyond horrible. The Pontiac 301 heads are also that bad according to the flow numbers.
Via3d
May 20, 2018 05:41 AM
DEL663
Oct 16, 2015 09:53 PM
69CutlassAlex
May 19, 2013 11:50 AM
flamez
Mar 22, 2010 01:57 PM
Oldwolf
Mar 11, 2009 02:34 PM
