Cylinder head bolt question
Hey guys,
Is it OK to use the same bolts after head repairs? If not, is it worth it to go to studs instead of bolts? This is for a 350 with 7 heads that will be decked to get a CR of around 9.5.
Thanks,
-Mike
Thanks,
-Mike
The only time I've used studs is for assembly alignment. I always reuse the head bolts unless there is an obvious problem. Follow tightening torques and sequences.
If you want to use ARP head bolts you could, as the others have said there is no reason to replace them. Olds engines aren't like 6.0L Fords and 4.6L Northstar engines, they don't need studs unless you are making some serious horsepower.
sadisticsavage
January 13th, 2014 12:01 AM
