cracked block
Old Nov 16, 2009 | 11:31 PM
AnthonyH'79Delta88's Avatar
cracked block
Hey, I was wondering if any one could help me. My plan was to put on an edelbrock intake manifold, a bigger cam, port and mill my cylinder heads. I was almost finished taking everything apart when I noticed these two cracks. How bad are they? Is my block toast? Or should I continue with my build? It ran fine before I took it apart. Here are three pictures of both cracks.Any help is greatly appreciated.
Old Nov 17, 2009 | 12:10 AM
crack p5.jpg[
Old Nov 17, 2009 | 12:11 AM
Old Nov 17, 2009 | 04:50 AM
Oldsguy's Avatar
Past Administrator
I don't think they are serious as they are from one water port to another. The best way to know for sure would be to have the machinist you plan on using to inspect it.
Old Nov 17, 2009 | 07:47 AM
citcapp's Avatar
Do as Dan suggests have the machinist check the block out. It needs to be done in any case
Old Nov 18, 2009 | 02:54 AM
OldsMotion's Avatar
OldsMotion
What year block is it? 350 or 403??
John
Old Nov 18, 2009 | 07:13 AM
'79 350
Old Nov 18, 2009 | 08:17 AM
OldsMotion's Avatar
OldsMotion
Originally Posted by AnthonyH'79Delta88
'79 350
Windowed main block with a crack. NOT worth your time or trouble to even go any further with it IMHO regardless of where the crack is.
Better to start fresh with an older solid main webbed block... pre 1975.
Like this one
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
John
Old Nov 18, 2009 | 04:20 PM
kaz442's Avatar
Looks like it froze. Time to look for a new block. Find an eariler one, they are stronger the the later. 350s are easy to find. You might be able to pick up a complete runner for reasonable $$. Where are you located, Maybe someone on here has one that is close to you.
JKaz
Old Nov 18, 2009 | 06:19 PM
45 minutes NW of the Twin Cities in Minnesota.
Ya it did, two years ago. I forgot about that until I had the heads off and saw the cracks.
I could even go with a 403.
Old Nov 18, 2009 | 07:24 PM
OldsMotion's Avatar
OldsMotion
There are a few guys in that area that have blocks you can use. Get the feelers out there. I bet you can get a block for next to nothing and a running motor for $300-400 OR LESS...
John
Old Nov 19, 2009 | 01:53 PM
I found a '70 350 engine with #6 heads, 4bc, it is gold, his buddy put a cam with .440" lift in it. He said it originally was on a 4speed car. I put my compression gauge on it and we turned it over with a ratchet. The first time he tried it we got 30PSI. Then I spun the ratchet and we got just about 90PSI. I thought that I could here the pressure leaking past the piston rings. I offered him $250 for it, and he didn't say for shure, but it sounded like he would probably take it. I think it needs a rebuild, but I'm not shure if that is that correct way to get a cranking compression. If it just needs piston rings and to be rehoned that is fine. I can just do that my self. If it needs an over bore and over size pistons that's getting spendy and I'd rather not go that way. What do you think? Doze it need the expensive or inexpensive way?
Old Nov 19, 2009 | 04:52 PM
Warhead's Avatar
Glad to see you found another engine.
I tried to build a 455 that had cracks like those-the freeze plug installation crcked the side of the block. It's JUNK.
If you got 90# with a ratchet, I'll bet you get 175 with a starter.
Good luck!!!
Jim
jawsmon
Jul 13, 2012 07:17 AM
OLDSmobility
Jun 2, 2011 07:44 PM
KRICHEN922
Dec 5, 2009 09:39 AM
ent72olds
Oct 21, 2009 06:41 PM
Jamesbo
Jan 10, 2009 06:49 AM
