Covering holes on heads
hey everyone, well, I was thinking of doing a little something for my cars performance this weekend, and Ive heard that you can remove the tubes in the heads by the exhaust manifolds. Ive heard that you remove them and put bolts to cover the holes where the tubes were. Does anyone here know if there are any adverse effects to doing this? Also, is removing the tubes and covering the holes all youre supposed to do or is there anything else?
First, there are NO easy, five minute, 20 HP improvements you can make. The entire engine is designed to work as a system and everything has to be matched to see significant benefits. The goal is to move more air in and out of the engine. Simply removing the tubes does exactly NOTHING unless you pull the heads, grind down the bosses inside the exhaust ports, upgrade to headers, and run a true dual exhaust system. Of course, at that point you need to upgrade the intake and change the programming on the timing curve. Then a new cam is in order, etc, etc.
The good news is that removing the A.I.R. tubes only will NOT trigger a check engine light...
I believe Joe is correct. removing the AIR tubes from the exhaust won't cause a check engine light. Air is injected into the exhaust manifold to lower HC emissions on older cars. The extra O2 helps burn the unburned fuel or HC.
If I aint going to feel any improvement, then I guess I wont do it. As for the emissions and check engine light I dont really care because my emissions arent checked and my check engine light has been on since 98 when my dad got the car. Thanks for your input.
Just to add to this a little, the A.I.R. injection into the heads is only functional when the engine is cold, before the O2 sensor heats up. After the O2 sensor comes on line (about 2-3 minutes after startup) the A.I.R. system switches all air to the converter tap to prevent overheating the cat. The only computer interface to the system is commanding the solenoids that switch the air from manifolds to cat to dump.
Pull the bulb out then, I did it to mine when I swapped in the 350. No CPU, Check engine light.
It's easy
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
joepenoso
Care and Appearance
October 21st, 2013 08:17 PM
coldfire
July 19th, 2013 08:20 AM
