Coolant in oil, 67’ 330
Old May 18, 2022 | 10:06 AM
Kirdid's Avatar
Just got the 330 fired up and immediately there is quite a huge leak of what seems to be oil and coolant coming from the oil filter area. Milky white/grey oil that’s really thin. Clean coolant coming out of the water pump and radiator.
Pulled the oil filter and replaced gasket from filter assembly to block. Clean coolant in the heads and some signs of coolant below the intake.
pulled the header on the afflicted side(passenger side) and i noticed no damage on the new head gasket but it looked a bit wrong. Can anyone tell me if the head gasket matches the head on the attached picture? Or if anyone has had a similar issue? There is almost no oil getting pushed into the driver side valvetrain.
To me it looks like the head gasket is covering some of the coolant passageways, is this gasket faulty?
Old May 18, 2022 | 10:58 AM
Those holes in the head casting are primarily used to clear the sand core molds out of the head. They are not all required for cooling. The gasket is designed correctly.
Old May 18, 2022 | 11:02 AM
Kirdid's Avatar
thank you
edit: one of the passageways is only partially covered, is that normal too?
Old May 18, 2022 | 01:00 PM
Yes, that is normal.
Old May 18, 2022 | 01:08 PM
Kirdid's Avatar
thank you, any idea as to where the oil is mixing?
Old May 18, 2022 | 01:12 PM
61Bat's Avatar
Fresh motor? Aluminum intake manifold? A loose intake could leak coolant into the crank case, ask me how I know.
Old May 18, 2022 | 01:21 PM
Oldsmaniac's Avatar
Water pump backing plate/timing covers are known to pit and eventually develop pin holes. A possibility for water in oil.
Old May 18, 2022 | 02:12 PM
What intake manifold and gasket/s are you using?
Old May 21, 2022 | 09:27 AM
Kirdid's Avatar
sorry for the late reply, i do not know the brand but it is original quality and the best i can source here. I changed both the intake and head gaskets and pressure-tested the coolant system with no coolant leaking from the pan so as far as i know the problem has been solved
Old May 21, 2022 | 09:28 AM
Kirdid's Avatar
thank you, i did make that mistake after putting it back together, so many bolts to keep track of
Old May 21, 2022 | 09:51 AM
What was the mistake for future readers?
Old May 21, 2022 | 09:54 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Was it the steel pan gasket? Even with the composite gaskets, RTV is needed around the 4 corner water ports on both sides of the gasket.
Old May 21, 2022 | 09:58 AM
A 330 does not use the turkey tray gasket because it has a drip pan bolted to the lifter galley. It does use steel shim gaskets but they are individual to the left and right intake banks.
Old May 21, 2022 | 10:43 AM
Kirdid's Avatar
I believe one of the intake gaskets dropped a millimeter when i put on the intake causing oil and coolant to mix in the galley and end up in the crankcase. But i am still having trouble with the engine
Old May 21, 2022 | 10:56 AM
Kirdid's Avatar
sorry but i have never worked on these engines before, what is the purpose of the steel drip tray inside the galley?
Old May 21, 2022 | 04:53 PM
It keeps the oil that slings off the rotating camshaft from hitting the bottom of the intake manifold and cooking on the exhaust crossover.
jensenracing77
Dec 5, 2013 12:23 PM
1966Oldsmobile
Mar 5, 2013 03:35 PM
805cut
May 8, 2012 10:02 PM
Kidcutty
May 28, 2011 11:55 PM
dr.chaos
Mar 3, 2011 04:25 PM
