Choosing the right pistons
Old Dec 29, 2013 | 02:49 AM
Oldskool84's Avatar
Domed vs dished vs flat , whats the pros and cons of each?
Old Dec 29, 2013 | 03:40 AM
captjim's Avatar
Piston choice is determined by the desired compression ratio, which in turn depends on the goals and purpose of the build. All things being equal I prefer a flat top for flame travel, but the most important thing is to get the desired compression ratio. Domed pistons (rarely used on Oldsmobiles) can be a pain due to clearance issues with the valves.
Old Dec 29, 2013 | 03:54 AM
Oldskool84's Avatar
Flame travel???
Old Dec 29, 2013 | 04:50 AM
joepenoso's Avatar
DON'T FORGET PISTON MATERIAL
Cast as in stock pistons or super hard hypereuretic (sp) cast
forged 2036 super soft or 4032 harder forged
joepenoso
Old Dec 29, 2013 | 04:52 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Really only flat top, 1.4cc, 3cc and 6cc in forged pistons. Only two have modern ring packs, the CP and Probe. But they are limited to a hone clean up and .030 over bore. Then there is the sbc 400 and rod combos.
Old Dec 29, 2013 | 04:55 AM
Oldskool84's Avatar
joepenoso
Joe i haven't the slightest clue of the difference and/or pros and cons of each, can u enlighten me?
Old Dec 29, 2013 | 05:08 AM
The Probe and CP are 2618 alloy and the Speed Pro are 4032, I believe. Some believe the 2618 is superior, softer but more forgiving for detonation. Either way forged are far superior to hyper or cast and only need slightly more clearance with modern designs. No hyper pistons are made for the 350, unless you go the 400 sbc piston and rod option.
Old Dec 29, 2013 | 05:14 AM
Oldskool84's Avatar
Ok thx!
Old Dec 29, 2013 | 06:05 AM
dancutlass's Avatar
Originally Posted by Oldskool84
Flame travel???
The spark from your spark plug ignites the air fuel mixture in your combustion chamber and a flame front travelling through it builds up. A flat top piston allows the flame front to travel faster and disperse more even along the piston head, which means to put it briefly, more power.
Old Dec 29, 2013 | 07:19 AM
cutlassefi's Avatar
Ehhh kinda.
Combustion chamber shape, spark plug location, fuel, and compression ratio also contribute to flame travel. There's more to it than just the top of the piston.
Old Dec 29, 2013 | 07:36 AM
dancutlass's Avatar
Ehhh kinda.
Yes sorry, Mark. I meant with all being equal, but the top of the piston!
Old Dec 29, 2013 | 07:39 AM
At this juncture, I think it fair to say:
OldSkool84, you are asking much better questions now, but you are asking questions that can't or shouldn't be answered on an internet forum.
You now need to go out and get some books (or even on-line resources) about engine design and performance and read them in order to gain a basic understanding of piston design, piston materials, head flow and porting, compression ratios, flame front propagation, valve and ignition timing, and carburetion / fuel injection.
See the current thread on home porting, for instance.
Once you have absorbed a basic level of knowledge, you will be better able to fix your own engine, and to ask the sorts of questions that will allow you to properly plan the sorts of upgrades you would like.
Old Dec 29, 2013 | 02:54 PM
Oldskool84's Avatar
Thx for your honest and straight forwArd input. Ive ordered most the reading materials you've recommended but am still playing the waiting game for them to arrive(ah the joy of being thousands of miles from the mainland... Sigh :/). Is there a particular book/dvd series that you'd recommend to explain carb vs efi ?
Old Dec 29, 2013 | 07:58 PM
I agree with the recommendations made above for books.
The Chassis Service Manual is essential for everybody, and you should have the Fisher Body Manual as well. Mondello's and Trovato's books are definitely helpful if you're considering modifying your engine.
The Chassis Service Manual contains clear simple descriptions of how every part and system works, including the carburetor and ignition.
"Timing and Vacuum Advance 101" by John Hinckley is helpful, as is "Distributor Vacuum Advance Control units
Specs and facts"
by Lars Grimsrud
The Rochester Carburetor Manual is good to read if you are going to use a QuadraJet, but most of what's in it is also in the Chassis Service Manual.
I also liked Cliff Ruggles's book on QuadraJets.
CarburetorManuals.com also has a number of different carburetor manuals.
Once you've looked through some of this stuff, you'll be in a much better position to ask questions that don't require several pages to explain, and don't lead to threads where people are arguing about the correct answers, and half of them are wrong.
Old Dec 29, 2013 | 09:26 PM
Oldskool84's Avatar
Specs and facts"
by Lars Grimsrud
Thx eric, ive deff got my work cutout for me! Lol
Old Dec 30, 2013 | 03:29 AM
DoubleV's Avatar
Oldskool84, much info can just be gotten free off the internet. Just google a topic of interest and you can find tons of good info. Keep in mind of course not every shread on info will be 100% true and some info can be debated, but at least you can learn the basics and that will be very helpfull to you.
Old Dec 30, 2013 | 11:34 AM
Oldskool84's Avatar
I kno, thats why i joined this site.
Old Dec 30, 2013 | 11:42 AM
rcrac3r's Avatar
Just on the topic of the "dished" type. I found out to late that there are both low & high compression dished pistons available in Oldsmobiles.
Old Dec 30, 2013 | 12:37 PM
Oldskool84's Avatar
Good to kno
Old Dec 30, 2013 | 03:46 PM
jag1886's Avatar
Most important thing is to realistically decide what you are going to use your engine for and what compression ratio you are aiming for. Next is what set of heads you are using, the combustion chamber size will dictate which set of pistons you have to use to get the desired compression ratio and which material you have to have. Don't over complicate it.
Old Dec 30, 2013 | 03:50 PM
Oldskool84's Avatar
No doubt
HitTheHole
Feb 1, 2014 12:04 PM
Al2011
Aug 24, 2011 06:58 PM
olds67
Jun 6, 2010 09:23 AM
1FSTLS1
Dec 20, 2008 05:45 AM
70cutty
Aug 13, 2008 05:48 AM
