choke range of motion
Old Sep 2, 2014 | 03:27 PM
Macadoo's Avatar
Hey guys,
Trying too set the choke on my Q-jet (it's electric if that matters) but I'm wondering; is it supposed to close ALL the way when cold and the pedal is pushed to the floor before starting, and open ALL the way when completely warmed up?
I noticed it wasn't opening all the way when warm, only a little more than half, so I set it to open all the way and now it won't close all the way when cold. I'm guessing I have to set the coil mechanism inside the housing but wanted to hear from you fellas first.
On a side note: have you noticed I've barely been on here since school started?
Old Sep 2, 2014 | 03:44 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes, that is how it works. Double check you have 12+ volts to the choke. Also check the choke coil contracts with voltage applied, they can burn out.
Old Sep 2, 2014 | 04:02 PM
Note that there are also specific adjustments for the choke rod and the choke unloader adjustment (the latter opens the fully closed choke by a certain amount at W.O.T. to clear a flood). Both are specified in the carb rebuild specs for your particular carb. These need to be set correctly before adjusting the choke coil.
Old Sep 2, 2014 | 04:48 PM
Macadoo's Avatar
Will do. Thanks guys.
Old Sep 3, 2014 | 11:20 AM
spate51's Avatar
Don't believe that choke valve closes all of the way. There is supposed to be a small gap (3/16" ?) when cold, but fully open when at operating temp. Varies by year and type of choke.
Old Sep 5, 2014 | 07:17 PM
Macadoo's Avatar
Thanks spate, I haven't had a chance to mess with it yet.
Diego
Feb 22, 2016 11:47 PM
SnakeBit
Aug 15, 2015 06:36 AM
toro68
Hurst/Olds
29
May 14, 2015 04:03 AM
GoodOldsGuy
Dec 13, 2013 12:10 AM
toro68
Feb 9, 2011 03:06 PM
