Charcoal canister necessary 1972 cutlass.
Old Nov 7, 2019 | 09:21 AM
Oldssupreme's Avatar
Chris
Hi! I'm having trouble finding the original location of the bolts for the charcoal canister mounting bracket on my 1972 olds 350 cutlass. Which brings me to my second question, is this necessary, or should I just route around it? I know it's a primitive emissions control, but is it needed, and if not, how would I go about routing the emissions pipe from the gas tank, and what to do about the front port on the carb where the canister would normally connect? Thank you
chris
Old Nov 7, 2019 | 09:57 AM
Chris, you can plug charcoal canister ports with vacuum caps. Be aware that this can cause your car to smell like fuel though. Especially when turning it off after a drive in the garage. There's really no need to delete a charcoal canister like removing restrictive catalytic converters or HP robbing smog pumps from later cars. It's completely passive. FWIW, I bet the charcoal canister was mounted in front of the passenger's side wheel well (where the battery is on the driver's side).
Old Nov 7, 2019 | 03:30 PM
VC455's Avatar
Barely Registered
That is the location. It mounts near the sheet metal of the fender. You will find holes there for the support bracket.
Old Nov 7, 2019 | 05:01 PM
Chris
Thank you. Is it totally on the core support or is one side resting on the plastic wheel well? Thank you
Old Nov 7, 2019 | 05:15 PM
RetroRanger's Avatar
72 Olds CS
Hi Chris
this is a 72 core support i know you used to have a 71 IDK if its different
hope this helps
dean
Old Nov 7, 2019 | 05:18 PM
VC455's Avatar
Barely Registered
Chris, here's a shot from the top. There are three mounting points for the clamp. Two bolts go through the plastic wheel well into the core support. One screw comes through the wheel well from the bottom.
Old Apr 6, 2020 | 06:46 AM
Roqetman's Avatar
With regard to car smelling like fuel... my ‘72 Cutlass 350 has recently started smelling of fuel after it’s parked. Stinks up the garage and interior. I do not find any fuel leaks. Does the charcoal canister vacuum line that goes to the carb need to be corrected to a timed vacuum port or manifold vacuum port or does if matter which one? Could the canister be bad, it’s original as far as I know. What else could cause the strong fuel odor in this system? Thanks!
72cutlassman
Nov 13, 2018 06:25 AM
rc_bloom
Aug 10, 2017 04:19 AM
bigin1978
Sep 28, 2015 07:51 PM
john116
Nov 16, 2014 12:01 PM
Hawk1061
Jun 12, 2012 03:58 PM
