Casting # F and a backward 3
Does anyone know what this casting # mean, F and a backward 3. Its lokated in the rear of the engine block.
The block has casting number 395558 #2,and i think its a datecode 236.
Best Regards
Best Regards
So is there any plan to remove the erroneous information from the Tech section (that was c&p from 442.com) saying that these numbers in some way indicate nickel content? Not trying to open a nickel content debate, but it seems the consensus is this number is meaningless to us, yet this information is still out there.
The FAQs on 442.com are a "dead" source, and should no longer be referred to. The Olds Wiki http://oldsmobilewiki.com/index.php/Category:Top_level is the place to go for more evolved and updated information. That information will stay on 442.com as long as the owner leaves it there. That doesn't mean it is correct. It does mean that you are looking in the wrong place!
Perhaps the easiest solution is to point the Tech link at the Wiki.
Last edited by jslabotsky; November 26th, 2009 at 06:57 AM. Reason: Added last sentence.
71Cutlass S
April 1st, 2014 10:15 AM
