Casting # F and a backward 3
Old Nov 25, 2009 | 12:05 PM
Oldwolf's Avatar
Does anyone know what this casting # mean, F and a backward 3. Its lokated in the rear of the engine block.
The block has casting number 395558 #2,and i think its a datecode 236.
Best Regards
Old Nov 25, 2009 | 12:17 PM
wmachine's Avatar
Trying to remember member
Okay, a '68-'76 350 block. The is no known meaning to the F3, general consensus (and I agree) is that it is simply a foundry casting revision identification. Same with the big blocks.
Old Nov 25, 2009 | 12:21 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I believe that is just the form number for the block casting.
I have seen F0 all the way up to F12.
Old Nov 25, 2009 | 01:12 PM
jslabotsky's Avatar
Telecom Guru
So is there any plan to remove the erroneous information from the Tech section (that was c&p from 442.com) saying that these numbers in some way indicate nickel content? Not trying to open a nickel content debate, but it seems the consensus is this number is meaningless to us, yet this information is still out there.
Old Nov 25, 2009 | 06:11 PM
I thought I already did. Has it come back?
Old Nov 25, 2009 | 06:23 PM
wmachine's Avatar
The FAQs on 442.com are a "dead" source, and should no longer be referred to. The Olds Wiki http://oldsmobilewiki.com/index.php/Category:Top_level is the place to go for more evolved and updated information. That information will stay on 442.com as long as the owner leaves it there. That doesn't mean it is correct. It does mean that you are looking in the wrong place!
Old Nov 26, 2009 | 12:34 AM
Oldwolf's Avatar
OK, These numbers have no important value.Thanks.
End of tread.
Best regards.
Old Nov 26, 2009 | 06:56 AM
jslabotsky's Avatar
Telecom Guru
I am aware of the status of 442.com. However, I was referring to information in the Tech section here at Classicoldsmobile.com, much of which originated at 442.com. For example: http://tech.classicoldsmobile.com/37.shtml
Perhaps the easiest solution is to point the Tech link at the Wiki.
Old Nov 26, 2009 | 07:36 AM
wmachine's Avatar
That would make a lot more sense than trying to maintain multiple data bases.
BackInTheGame
Jan 6, 2015 04:57 PM
71Cutlass S
Apr 1, 2014 10:15 AM
421-6speed
Nov 30, 2011 08:00 PM
olds4life
Aug 6, 2009 01:45 PM
omega73
Aug 17, 2006 07:24 AM
