Carb Question
Old Jun 19, 2009 | 04:58 AM
Gbobby's Avatar
all olds...all the time
Carb Question
I have an Edelbrock 1406 carb that I bought used. I had it on the 403 that was in my Regal and it seemed to run rich in the right bank. I never did get it adjusted right because the motor was not running right at the time. Now that my 350 is rebuilt I would like to adjust my mixture screws back to factory specs before starting the car-I do not want to dump fuel in my new bottom end. Does anyone know where the factory settings are? I read on a few of the "other guys" forums that the setting should be 3 turns out from where the mixture screws seat but I trust my OLDS guys alot more than those "other guys". Any help here would be appreciated.
Old Jun 19, 2009 | 06:25 AM
I'm not aware of a "factory" installation for an Edelbrock carb, so it's difficult to give you a "factory" adjustment. The reality is that whether the idle mixture screws are 1 1/2 turns out or 3 turns out at start up won't make a bit of difference as to dumping gas. How many times you pump the accelerator pump will be the important issue.
Old Jun 19, 2009 | 08:18 AM
A good place to start with a Q-jet is 2.5 turns. Set it between 1 and 3 and then use a vacuum gauge to set the idle mixture screws. Set them for maximum vacuum. You can also use a tach to set them for maximum RPM.
Old Jun 19, 2009 | 09:03 AM
Gbobby's Avatar
The only problem is that I just put a new cam and I need to break that in before I start tuning the carb. I think for initial start up I will turn them out 1 1/2-2 turns.
Old Jun 19, 2009 | 09:28 AM
If you are running the engine at 2500 RPM to break in the cam, the setting on the idle screws won't matter. You'll be running off the main circuit at that RPM.
Old Jun 19, 2009 | 10:21 AM
cutlassefi's Avatar
Carb
Joe hit the nail right on the head. Chances are the carb is probably fine as well, you had a poor running car to begin with.
Old Jun 19, 2009 | 10:53 AM
Gbobby's Avatar
I did reset those screws and discovered the right mixture screw was stiff as I turned it in. I pulled both screws out and cleaned the ports with a small brush and throttle body cleaner which solved the stiffness problem. Good point Joe, I didn't even think that it wouldn't make a diff above 2000 rpm. I guess I am just a little wasted with trying to get this together and it being so hot out. Thanks again for all of your wisdom guys!
Don R
Oct 6, 2012 09:47 AM
RandyS
Oct 4, 2012 12:36 PM
george88
Jul 29, 2006 11:20 AM
mjregim
Jul 24, 2006 12:43 PM
