C heads on a 350
Old Jan 22, 2022 | 09:44 AM
65-330's Avatar
C heads on a 350
Built 350 i'm looking at buying. Making about 300 hp. Has 7a heads, valve job but no porting, but I can get a good set of C's all done, for really good price. Will it work? Any help will be appreciated.
Old Jan 22, 2022 | 09:52 AM
coppercutlass's Avatar
Chevy budget Olds powered
It will work but you won't see any real benifits over the sbo unless you really rev it up. I recently just got done building a J headed 350 and will be spun past 6500 my current sbo spins to 7k rpm with ported #6 heads. With just big valves and a little bowl work one of my previous engines easily spun to 6500 and made 370 ish HP
Old Jan 22, 2022 | 10:02 AM
7a heads typically have 66-70 cc combustion chambers. C heads typically have around 80 cc, so the compression ratio would drop a LOT by swapping heads.
Old Jan 22, 2022 | 10:30 AM
^^^THIS. Unless you plan to change the pistons and use a port-matched Performer RPM, you'll likely hurt performance with this swap.
Old Jan 22, 2022 | 12:29 PM
65-330's Avatar
Thank all!
1970supremevert
Jan 30, 2013 03:20 PM
deltaroads
Oct 30, 2011 12:10 PM
theoldsrocket
Jun 1, 2011 04:58 PM
flamez
Mar 22, 2010 01:57 PM
deltathunder
Jul 29, 2008 03:08 PM
