A/C 72 supreme 350
Old Oct 14, 2019 | 07:15 PM
Oldssupreme's Avatar
Chris
A/C 72 supreme 350
Hi everyone! What do I need to cap off and how would I go about doing it- I am not planning on immediately hooking up my a/c system. I am not going to install the compressor roght now so I'd like to cap all the oil/fluid lines that run to/from the a/c heater box. Is this possible? Would the electric still get hooked up as normal other than to the absent compressor? Any precautions I need to take? What types of caps should I use? Thank you,
Chris
Old Nov 2, 2019 | 05:50 PM
Chris
Any thoughts? Thank you!
Chris
Old Nov 3, 2019 | 03:49 AM
Mine was removed when I bought the car back in 1994, it was left open so the damage was done. Moisture and crud gets in the system. So when I finally got it going again I replaced most all of it. If you think you will be putting it back on someday why not just leave it on and keeping it sealed? I suppose if you really need it all out of the way then try to make some caps or plugs but I have no idea if you could get something like that... The electric part you should be able to leave, I would just coil up the wire that went to the compressor clutch and make sure it doesn't get damaged or grounded out.
Old Nov 3, 2019 | 04:55 AM
don71's Avatar
same but different
You might visit the plumbing section to find some fittings. I did that years ago. As a result of father time, I have no idea what sizes you'll need. A quick glance with a tape measure might be helpful though it might involve two trips to said store.
Old Nov 3, 2019 | 07:36 AM
Get some large heat shrink tubing and some old inner tube rubber. Cut the rubber so it goes over the end of the hose or fitting with a flap that can be enshrouded in the heat shrink when its slipped over it. Shrink the tubing.
Old Nov 4, 2019 | 09:45 AM
cdrod's Avatar
Rodney
That’s a great idea!
RickH
Tech Editor's Desk
Jun 10, 2014 07:23 PM
Napoleon1991
May 16, 2013 06:29 PM
Jetstar 88
Apr 29, 2012 10:00 PM
meads
Feb 12, 2012 10:17 PM
Lady72nRob71
Jul 4, 2011 05:49 PM
