'built 350 hp ?
I'll get the build sheet. Has edelbrock intake , headers with magna flow mufflers and yes the compression measures 10.68 . The block was decked and heads were milled and bowls were blended and opened ports up and intake also.
The more information you give the better you can estimate the power...but even that isn't absolute. The only way to really tell is to dyno it.
Mine makes about 360-375 with 9.7:1, a better intake, more cfm, with a similar sized roller than their flat tappet.
Depending on the cam, probably 450 max on this build. I did a roller (226/234 on a 112) for a guy in Va. with an Edelbrock headed 350. He dynoed it and it made about 350hp with 9.0:1, an RPM and a 700 Holley.
But it started making over 400lbft of torque at 3000.
BAFRAYD
May 16th, 2014 07:48 PM
