Timing & jetting ideas on built up 350
Old Aug 23, 2012 | 05:14 PM
tinner's Avatar
I have a relatively fresh 350 Olds that has had some performance work done to it.
#5 heads w/mild port work (clean up and bowl blending)
Larger valves
comp XE284 cam
roller tip rockers
Recurved HEI
9.8:1 compression
RPM intake
Headers
Holley 770 street avenger carb
I don't know what baseline I should time this thing at and also, I would imagine that the carb is probably somewhat fat for this. If anyone has some input, it would be great. I am in Wisconsin. If there were any specs on the recurve...I never got them as the prior owner had that done. Thanks
Old Aug 23, 2012 | 06:53 PM
380 Racer's Avatar
That combo sounds pretty good to me. That 770 should work fine.IMO I would start about 10-12* advance and have it come in with a total of 32-36*. I had one set-up that liked 40* total, so you just have to try and see.
Old Aug 24, 2012 | 12:39 PM
tinner's Avatar
Thanks much!
Old Aug 24, 2012 | 01:27 PM
cutlassefi's Avatar
Originally Posted by tinner
Thanks much!
You have a lot of cam for that size motor and compression ratio.
I'd start with16 or so initial with 36 or so at 3000. Hope you have a 3.90 or better gear.
brown7373
Oct 22, 2014 07:35 PM
sqeeek
Feb 26, 2014 02:35 PM
Nufo
Aug 8, 2013 10:16 PM
67Olds442X2
Feb 11, 2012 01:05 PM
442scotty
May 13, 2009 05:42 PM
