Block number appears to be blank
Old June 7th, 2008 | 07:07 AM
GoBigRed's Avatar
71RedCutlassConvertible
Question Block number appears to be blank
I found the "What year is my engine!?!" very helpful in finding my block number. However, when I found the pad, it was blank. The place I am looking is from under the car and located under the #1 plug. There is a battery ground connection attached to the front of the boss.
Am I looking in the correct place?
Did the factory make a mistake?
Old June 7th, 2008 | 11:07 AM
Old June 7th, 2008 | 12:59 PM
344870M's Avatar
http://www.pbase.com/drillbit/image/626075
Here's what you should be seeing.
A blank pad indicates a service motor. Sometimes an erroneous number is stamped into the pad depending on the dealership practices.
Hope this helps.
~Ken
Old June 7th, 2008 | 05:11 PM
GoBigRed's Avatar
Thanks Ken, the pad is very clear in the photo and is what I was looking at. The block must be as you describe with no misc. stamping.
507OLDS
April 28th, 2014 03:45 AM
73aussie455
February 12th, 2014 01:06 PM
halfmoontrail
January 27th, 2013 04:08 PM
halfmoontrail
June 22nd, 2011 11:15 AM
barquecat
February 12th, 2008 07:12 AM
Quick Reply: Block number appears to be blank
