Bigger valves on 7A heads
Old Oct 30, 2018 | 05:41 AM
ajr2820's Avatar
Is there a significant gain in flow to be had from moving from the small valves to the big valves with these heads?
Old Oct 30, 2018 | 06:27 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Which heads 307 or 350?
Old Oct 30, 2018 | 06:45 AM
ajr2820's Avatar
Sorry. For a 1972 350
Old Oct 30, 2018 | 09:13 PM
Yes, it definitely helps, think of the W31 with 2"/1.625" valves. Of course the bowls need to opened with a cutter at minimum, even better with a grinder to transition into the port.
Old Oct 31, 2018 | 04:29 AM
ajr2820's Avatar
What cost is typical for having this work done?
Old Oct 31, 2018 | 06:27 AM
I depends a lot on the shop rate in your area and the condition of your heads. Also make sure enough clearance is reamed into new valve guides, machine shops seem to put them in with not enough clearance on the center exhaust guides. If the guides aren't all wasted, it helps cost. I think a pair runs from about $800 to $1200 depending on the extent of the work. Mine #6 heads were $400, fresh machined with big intake valves bought them unused and fresh machined off Kiijji. Up here in Canada since stuff costs more, I was told they were $1200 worth of work, I would believe it. The cost is close to a set of Procomp heads but you need an electric fuel pump and screw in studs, guide plates and roller rockers to go with the aluminum heads, along with at least a .030" mill to reduce chamber volume for a 350. Also cheap Felpro head gaskets aren't recommended with aluminum heads so add another $150 for Cometic's over Felpro head gaskets.
truckerlary
May 22, 2015 07:09 PM
theoldsrocket
Jun 1, 2011 04:58 PM
flamez
Mar 22, 2010 01:57 PM
dman0712
Jan 5, 2010 09:32 PM
skryla
Nov 19, 2008 10:04 PM
