Anyone use this edlebrock part?
Old Jun 9, 2010 | 11:22 PM
80_cutlass's Avatar
It is a pair of cross over plugs for olds....pn 2733. I want to use them when I put my motor back together. Will they work for the SBO heads?
http://www.summitracing.com/parts/EDL-2733/
Thanks,
sb
Old Jun 10, 2010 | 10:08 AM
cutlassefi's Avatar
Yes they'll work but I recommend filling the crossovers and welding or surfacing the center exhaust divider instead, instant hp gain.
Old Jun 10, 2010 | 01:45 PM
80_cutlass's Avatar
I'll bite.
What do you use to fill the crossover? Melted chevy pistons?
What are you talking about the center divider?
Won't this piece take the place of filling the crossover?
sb
Old Jun 10, 2010 | 04:03 PM
cutlassefi's Avatar
Based on your PM forget it. You're using manifolds so just stay with the plugs.
Old Jun 11, 2010 | 05:55 AM
I've heard the exhaust crossover plugs can come loose and rattle. I decided not to use them in my Edelbrock intake manifold.
Old Jun 11, 2010 | 06:32 AM
Eddie Hansen's Avatar
My Machinist made plates for the heat crossover on my manifolds, then he machined the manifold and welded them in, then surfaced the mating areas, he did NOT plug the heads as my build wasn't for racing?? I don't know if i picked up any ponies, but I am sure the manifold will be a little cooler.
Old Jun 11, 2010 | 05:28 PM
80_cutlass's Avatar
My 4A heads already have a divider built up, where as my 3As had none. Perhaps I need to rethink this exhaust thing.
sb
Old Jun 11, 2010 | 11:05 PM
The Stickman's Avatar
I am using them and have had no problems. I had to grind them down some to fit before pounding them in. The intake runs much cooler now.
Old Jun 12, 2010 | 07:41 PM
80_cutlass's Avatar
These go in the intake, right? I was hoping they went into the head to make quick divider between the ports.
How does one go about filling in the space there between the exhaust valves to make it two ports?
sb
Old Jun 12, 2010 | 10:22 PM
sb
They go into the heads to fill the EGR crossover.
Old Jun 13, 2010 | 10:56 AM
67 Cutlass Freak's Avatar
Here's some links to other threads that should answer most of your questions -
http://btrperformance.com/phpbb/view...php?f=1&t=2245
http://btrperformance.com/phpbb/viewtopic.php?f=14&t=90
Old Jun 13, 2010 | 03:32 PM
80_cutlass's Avatar
Cool. Plenty of reading there. I think I've got it now.
sb
JpMotorsports
May 15, 2014 07:08 AM
GothamCity
Feb 4, 2009 12:15 PM
72 Supreme
Jul 17, 2008 03:42 PM
jrblanke
Jan 10, 2008 05:19 PM
