removed old rochester carb and installing edlebrock
Guys,
I am in the process of changing my intake and carb. I have installed the edelbrock rpm intake, and removed the old rochester carb.The problem I have is the edelbrock 650 cfm carb looks different from the old carb and has more connections. So does anyone have pics of similar carb on and olds 350. So that I CAN compare what hose goes were?? Thanks in advance
Well, in general, you have the vac. advance, the pcv hose, possibly a vacuum to the trans, one to the brake booster, and one to a vacuum ported switch that is temp regulated and feeds vacuum to egr, etc.
So, without knowing your particular setup, I hope this is of some help.
Kidcutty
Jun 17, 2010 07:48 PM
