Alternative to stock heater valve?
Old Apr 27, 2026 | 04:27 PM
JBinMT's Avatar
This is a ‘72 Cutlass S, 350 with original AC.
I’ve had to change my heater valve twice now, and it ends up being a real pain in the butt. It’s the one offered by the major parts houses; it threads into the intake manifold at the rear. The shape of this valve requires that I detach the transmission dipstick tube in order for there to be enough room to unscrew the valve out and install the new one, and my fat old guy hands are just baaaaaaaarely able to get in there and thread that bolt out to get the dipstick tube detached.
My solution is to install a 5/8” hose barb in the intake manifold, hook the hose directly to that, and splice an inline-style heater valve in the hose a few inches downstream of the barb.
I figure I can’t be the only one to have thought to do this, so I’m wondering if anyone has found a good vacuum-controlled inline heater valve they’d recommend. A lot of similar GM makes from that era seem to have heater valves like my original one, which would still be a pain to screw/unscrew, so maybe I'm looking at a Mopar one or even one from *shudder* FoMoCo.
Any suggestions before I go start wandering the part stores? Thanks!
Old Apr 27, 2026 | 04:47 PM
VC455's Avatar
Barely Registered
Before wandering too far from OEM, realize that Olds changed the actuation on the Cutlass heater control valve around 1970. Make sure you know if you want vacuum-to-open or vacuum-to-close when you get a brand X valve.
Someone will comment on which you need. I don't have that in my memory bank.
Old Apr 27, 2026 | 05:01 PM
My response is certainly not to confuse you, but this topic raises its head quite often. Here is a thread which might provide a tad bit of insight until one of the heater valve gurus respond.
NOTE: The discussion about the 1972 model year by other members (might be beneficial to you). Good Luck!
Correct heater valve
Old Apr 27, 2026 | 05:28 PM
Yes there are “other makes” heater valves that are inline with the heater hose and not screwed into the intake. As VC455 said above, you need to ensure you get the correct vacuum operation; other than that your Olds won’t know that it’s a Ford, Chevy, or MOPAR valve.
Old Apr 28, 2026 | 03:47 PM
JBinMT's Avatar
I appreciate the feedback and the link - I’m pretty sure I found one that will work. I’ll update when I confirm. Might even post pics for anyone else wanting to go this.
Old Apr 28, 2026 | 04:03 PM
Hope the repair goes well. Look forward to seeing that pic.
Old Apr 28, 2026 | 05:07 PM
1972-older Cutlii use a valve that is normally closed and opens when vacuum is applied. Most valves available today work opposite of that. The easy way to tell is to try to blow through the valve when it is not installed. If you can, it's the wrong one.
Old Yesterday | 02:16 PM
JBinMT's Avatar
Success!
Spent $20 at O’Reilly’s for the exact heater valve I had in mind.
Part number at O’Reilly’s
Not as big as I thought it would be.
Here it is installed, and you can see the 5/8” hose barb and adapter threaded into the intake manifold. MUCH easier to deal with than threading in the old brass unit. I had to get the adapter on Scamazon; it’s a 1/2” NPS female to 3/4” NPT male reducing bushing. I chose 1/2” on the female side because it’s super common for whatever you want to screw into it.
Here it is installed, and you can see the 5/8” hose barb and brass bushing threaded into the intake manifold. MUCH easier to deal with than threading in the old brass unit. I had to get the adapter on Scamazon; it’s a 1/2” NPS female to 3/4” NPT male reducing bushing. I chose 1/2” on the female side because it’s super common for whatever you want to screw into it.
Old Yesterday | 02:23 PM
Go back and read post #7. 74612 is a normally open valve that closes when vacuum is applied. That is the opposite of what your car needs. Your next thread will be asking why you have heat all the time or not when you want it. By the way, I used that valve on my 1985 307 cars for exactly the same reason. It works great there because those cars need the normally open valve.
Old Yesterday | 02:41 PM
JBinMT's Avatar
Maybe my car is an oddball, but this is the one I needed.
Old Yesterday | 02:44 PM
The one you needed based on what?
Humor me. With the engine running and the heater control in the HEAT position, do you have vacuum on the hose to the valve or not? How about when the heater control is in the MAX A/C position?
Old Yesterday | 02:58 PM
NEW - OUT OF BOX - Genuine Ranco (OEM GM) H25-124 Heater Valve
Old Yesterday | 03:08 PM
I think the correct Murray p/n = 74602; not 74612.
74602 = normally closed
74612 = normally open (as has been previously stated)
Old Yesterday | 03:30 PM
JBinMT's Avatar
Originally Posted by joe_padavano;[url=tel:1678614
1678614[/url]]The one you needed based on what?
With the heater on, but turned all the way to “cold”, I have vacuum to the heater valve, so it’s closed. As soon as I turn it at all towards “warm”, the vacuum drops out, the valve opens. Anything else?
Old Yesterday | 09:16 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
To keep the OEM valves alive and the rest of the cooling system make sure coolant isnt acidic. Actuate the valve every time you're in the car...or at least when you think about it.
1987CadillacBrougham
Jul 21, 2024 02:55 PM
dc2x4drvr
May 26, 2022 12:45 PM
Rustbucket2
Jun 11, 2018 04:33 PM
1973olds98
Oct 30, 2009 04:54 AM
metro411
Oct 17, 2007 05:18 AM
