correct heater valve
Old Apr 20, 2020 | 03:36 PM
coppertopgmc's Avatar
what should the correct heater valve look like for a 71 Cutlass with the 350 look like, hose nipple out the side or out the top?
Old Apr 20, 2020 | 05:23 PM
All of the ones I have seen have the nipple out the side, but then again I worked at auto parts stores in the 80s and sold aftermarket parts and not factory parts.
Old Apr 21, 2020 | 01:42 PM
I just pulled the one off the parts car that is a 72 cutlass, don't know if its correct because its open until I put vacuum to it then it closes and I thought i saw on here somewhere that its supposed to be normally closed until you put vacuum to it then it opens?
Old Apr 21, 2020 | 01:49 PM
tru-blue 442's Avatar
Old School Olds
https://www.rockauto.com/en/moreinfo...17494&jsn=2209
https://www.rockauto.com/en/catalog/...ter+valve,6860
Old Apr 21, 2020 | 02:14 PM
That is a later normally open valve, so it's been replaced.
Old Apr 21, 2020 | 03:40 PM
Below is from an old post about this topic.
https://classicoldsmobile.com/forums...-valve-120656/
I have the same valve on the shelf for my car.
It is stamped with:
TYPE H25
RANCO
COLO, USA
The backside has an ink label:
H25-124
The valve is normally open and takes vacuum to close.
Just today I was working on the car, changing the heater core and I'll install the new heater valve tomorrow. I connected a vacuum gauge to the heater valve vacuum hose on my car and it has no vacuum with the temp slider on WARM and vacuum with the temp slider on COOL, so this valve matches my car's vacuum operation.
I recommend you check the vacuum operation on your '72 to ensure it matches your heater valve as my '71 operates opposite of what the factory manual describes per Joe's posts.
More information in this thread about the difference in vacuum and heater valve operation (normally open vs normally closed) for the A bodies. Note that this information is different than what Joe pointed out in the CSM, which claims the change was made in 1973 but actual measurements show it was made in 1971, which coincides with the changes in water pump nipple sizes and the heater valve thread size.
https://classicoldsmobile.com/forums...estion-108677/
1970 Supreme operation:
Originally Posted by 96powerstroke
My car does apply vacuum in the heat position and none in the cool position so the valve must be operated by vacuum.
1971 Supreme operation:
I just checked my 1971 Cutlass Supreme by connecting a vacuum gauge to the heater control valve vacuum hose in the engine compartment.
Slide control set to COOL = vacuum
Slide control set to WARM - no vacuum
friesjh
Dec 18, 2018 08:55 AM
Rustbucket2
Jun 11, 2018 04:33 PM
jensenracing77
May 31, 2014 11:05 PM
Bushbunny62
Sep 20, 2010 07:05 PM
1973olds98
Oct 30, 2009 04:54 AM
