Air Cleaner Color
Air Cleaner Color
All,
Im in the process of decontaminating and repainting my engine compartment. What color should my air cleaner be? Someone painted it black, but there seems to be red paint underneath and chrome on the lid. Whats the deal?
It also look like this air cleaner is pretty restrictive, should I ditch it and get an open air one? Im trying to stay somewhat original, but it look like this air cleaner is very restrictive. I am planning to stick with the 4 bbl ROACHester and stock intake manifold.
Its a 69 cutlass with the 350/4bbl
It seems someone has been changing, or at least re-paiting engine parts. You have a blue engine, with gold valve covers and a black air cleaner cover. I would go with the colors you like if you aren't trying to restore your car. The aftermarket chrome air cleaner would look nice and probably offer less restriction but unless you plan on rebuilding your engine and going something other than stock then it really wouldn't make that much difference. I can't remember what engine Oldsmobile painted blue. Anyone????
I've seen worse....
Part of the purpose for the horn on the air cleaner is to direct cooler air into the carb. Open element definately flows more freely, but your air charge will be a lot warmer...except when the motor is cold and you WANT it warm.
Head out to the junkyard and look at mid 70 and up Ch#vy and G&C pickups. They used QJets and a lot had a less restrictive dual horn...one inlet toward each side. And you can still use your pre-warm tube off the manifold. Probably be pretty handy up there in NY during the un-summer months.
JMHO.
C.J.
C.J.
C.J.
RAMBOW
Dec 7, 2017 07:22 PM
69CutlassAlex
Dec 2, 2011 08:01 AM
