engine quesions
Old Jan 22, 2007 | 10:31 AM
ct1979's Avatar
engine quesions
What should the compression check be on at '69 350. Mine is stock.
Also what would the ideal vacuum pressure be at idle?
Old Jan 23, 2007 | 12:26 PM
70Wcars's Avatar
Lots of variables on an older motor, but look for compression no lower than 120 on a motor still tight enough to run well...Vac. depends on cam, but a stock set up should be 15 or more inches merc. and steady if no leaks...
Dan S.
Old Jan 23, 2007 | 02:14 PM
ct1979's Avatar
Thanks! I am getting a very steady 19 on the vacuum gauge. I may just wait on the rebuild I was thinking about as long as the compression seems good. It was lower but some small carb adjustments brought it up and smoothed it out.
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
cts-v
Jan 10, 2009 06:20 PM
pinky
Oct 1, 2007 11:24 AM
