88 307
More to the point, why do you want to change to a 2bbl anyway? You can easily disconnect the vacuum hoses that you don't need and cap them on the stock intake. Your bigger problem is removing the computer controlled Qjet. The computer controls both the carb and the distributor. It requires signals from both to function properly. Removing either will disrupt the computer system and send it into "limp home" mode. If you are going to disconnect the computer, you need to replace BOTH the carb and the distributor with pre-computer parts. You can use a pre-computer Q-jet that bolts to your existing intake and a pre-computer HEI distributor.
<mr.stew@netzero.net>
Oct 18, 2004 11:20 AM
