83 307 problems
Old Jul 22, 2016 | 02:37 PM
  #41
Jonlaw85's Avatar
Originally Posted by Northern Custom Cruiser
I doubt that has to due with the backfiring, but maybe with the idling.
tomorrow hopefully ill get the chance im going to pull the fuel filter and spray it out in there with some c&c cleaner and see if that helps (w/out the filter) maybe i put it in backward and it just happens that im getting the same results in running from the bad alt/bat and me being a dip
Old Jul 23, 2016 | 12:40 PM
  #42
Jonlaw85's Avatar
Rear butterflies are seized, won't move, hey I bet that'll do it
Old Jul 23, 2016 | 01:11 PM
  #43
Jonlaw85's Avatar
Figured out the buttfly issue, I'm an idiot but while looking found the choke tube it's snapped
Old Jul 23, 2016 | 02:14 PM
  #44
jcdynamic88's Avatar
i have had more than one of those cars with a bad map sensor that caused backfiring,bogging and just awful performance with no check engine light. the sensor was stuck on 2.5 volts and not moving from .5 to 5 volts like it should. you will need a scanner capable of data stream info to find a problem like that. the early computers weren't much help.
Old Jul 23, 2016 | 06:07 PM
  #45
Jonlaw85's Avatar
One more update, running better, now flooding and backfiring terribly until the secondaries open then it screams. Fixed the choke hose, cleaned a few sensors removed fuel filter and sprayed cleaner inside. Changing carb tomorrow hoping that will either fix it or help figure it out
Old Jul 24, 2016 | 02:14 PM
  #46
Jonlaw85's Avatar
Changed the carb and all is better! Idles a bit high but I'll take it! All of the bolts including the mounts were all hand tight, think I'll rebuild it now, thank you all for the help!
chasman414
Jun 25, 2020 07:05 AM
carbonf00tprint
Nov 4, 2012 07:53 AM
jrbarrie83
Jul 9, 2006 09:26 AM
leo lymen
Dec 13, 2002 06:48 PM
