73 delta 88 royale engine
Old Apr 14, 2014 | 01:39 PM
ao177snipe's Avatar
I have a 73 delta 88 royale 2dr and the 350 rocket engine is knocking real real bad, what I am wondering is god forgive me will a chevy 350 bolt right in. I have been having trouble finding rebuild kits for the car, I have been told it will be hard to find them, any help will be greatly appreciated. Thanks in advance. steve
Old Apr 14, 2014 | 02:07 PM
captjim's Avatar
The 350 Chevy is not an bolt-in swap. Rebuild kits are not hard to find, either are running 307s, 350s, or 403s, all of which will bolt right in.
Old Apr 14, 2014 | 02:11 PM
tru-blue 442's Avatar
Old School Olds
It can be done. Not an easy swap.
You may try your local Craigslist
to see if there is a small block Olds
engine available in your area.
You may also start a thread in the parts
wanted section. There are fellows here
that may have just the engine you need
for a straight bolt in. The 307 330 350 403 is
pretty much as easy as it will get.
Does it have to be rebuilt or will a good used
one do for now?
Good luck with the project. Post some pics
when you get the chance.
Old Apr 14, 2014 | 02:35 PM
A Chevy swap would entail not only the engine but also a transmission, your current trans will not work. The most economical route is what the others suggested or rebuilding yours.
I've dealt with them on other makes.
http://www.egge.com/kits?make=OLDSMOBILE
Old Apr 14, 2014 | 02:41 PM
Professur's Avatar
There are fresh crate engines in the after market if you don't want to deal with rebuilding yours. Don't cost any more than a similarly assembled bowtie, but all your existing accessories will just bolt right up. If you go bowtie, figure replacing everything that bolts to the engine as well. If you're thinking of getting a wrecker yard chevy with all it's accessories and such, you're 50-50 on bolting in someone else's troubles.
Old Apr 14, 2014 | 04:28 PM
Kennybill's Avatar
Where are you located? Ken
Old Apr 15, 2014 | 11:30 AM
ao177snipe's Avatar
In Clarksville TN on Ft Campbell Army Base, about 45 NW of Nashville
KetsMcLets
17
Apr 26, 2020 01:40 PM
Bigball
Mar 24, 2012 05:09 AM
82olds88rayale
Oct 12, 2009 07:57 PM
Oldsmobile Jo
May 20, 2004 05:55 PM
<Dennis Oliver>
Mar 14, 2004 08:58 AM
