73 350 rocket exhaust manifold HELP!!
Old Mar 18, 2015 | 05:57 PM
fr35htilninja's Avatar
I pulled my 73 350 rocket out of a donor car to drop into my 80 cutlass. I wanted to use the stock manifolds but have dual exhaust. The only problem im having is finding the exhaust block off plate for the passenger side manifold. The one i did find said it would only work on a 68-72 olds 350, im pretty sure it would work but was wanting someone with a little more knowledge than me to give their opinion!
http://www.ebay.com/itm/400502972234...%3AMEBIDX%3AIT
Old Mar 18, 2015 | 06:13 PM
Welcome to the site, that should work fine.
Old Mar 18, 2015 | 06:22 PM
Rustbucket2's Avatar
It is the same one, I used on my 73 350. It will work.
Old Mar 18, 2015 | 07:32 PM
One more question then, it may sound stupid but i would use it to block off the port where the crossover pipe connected on the passenger side exhaust manifold right?
Old Mar 18, 2015 | 07:41 PM
nsnarsk65cutlass's Avatar
That's correct.
Old Mar 19, 2015 | 07:37 AM
pherbicide's Avatar
I was actually about to start a thread asking this same question. Thank you for the insight!
Old Mar 19, 2015 | 08:53 AM
This cap will work on every RWD SBO passenger side manifold from 1964-1990, including the tubular manifolds on the 1985-1990 307s with 7A heads.
yeahbuddy
Mar 12, 2016 12:29 PM
olds408
Aug 6, 2014 05:38 PM
atkinsom
May 29, 2013 06:39 PM
