71 350 build spec's
Old Aug 13, 2008 | 08:38 PM
woodie582's Avatar
71 350 build spec's
Engine built by previous owner, I am mostly curious about the cam choice. 4 speed with 3.23 rear end. I'd like to have the stock Q jet rebuild and used.
.30 over with speed pro forged flat tops
cylinder heads at 69 cc
stated compression 9.8 to 1
crower cam. gross lift 488in 494ex
center line 108
duration at .50 215 221
lobe lift 305 308
lobe seperation 112
intake 2.07 exhust 1.60
headers
performer rpm
holly fuel something or other carb
Petronix (sucks leave key on for a few seconds or crank away)
Nice lope at idle, pulls hard.
Thanks for the input.
Old Aug 16, 2008 | 11:22 AM
woodie582's Avatar
Any input?
Old Aug 16, 2008 | 11:57 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Sounds similar to mine. What was done to the heads?
Bore Size:
4.089
Stroke:
3.385
Displacement:
355.609 cubic inches
Piston:
Speed-Pro forged flat-top
Rods:
6" reconned stock Olds forged rods
Crank:
standard rod, standard main, stock stroke, balanced (external), bobweight: 2227 grams
Main Clearance:
#1- .0030
#2- .0032
#3- .0035
#4- .0035
#5- .0043
Rod Clearance:
#1- .0032
#2- .0030
#3- .0031
#4- .0031
#5- .0030
#6- .0027
#7- .0025
#8- .0025
Rod Side Clearance:
.015
Piston-to-deck:
.030
Piston-to-wall:
.0045-.0048
Top Ring End Gap:
.018-.020
2nd Ring End Gap:
.020-.022
Compression Ratio:
9.82:1
Dynamic Compression Ratio:
7.85:1
Head Gasket Thickness:
.039
Head CC Volume:
67ccs
Intake Valve Size:
2.070
Exhaust Valve Size:
1.625
Intake Flow #s (stock)
.100- 80 (50)
.200- 145 (105)
.300- 185 (148)
.400- 207 (170)
.500- 209 (180)
Exhaust Valve Flow #s (stock)
.100- 71 (40)
.200- 112 (75)
.300- 149 (105)
.400- 174 (135)
.500- 179 (145)
Intake Seat is 30 degrees
Exhaust Seat is 45 degrees
Lunati 318a3 cam
Heads can support 464HP @ 6200RPMs
Old Aug 16, 2008 | 12:06 PM
center line 108
lobe lift 305 308
lobe seperation 112
I think that is a decent cam choice for a pretty quick street car.
My lunati is .485 in .485 ex
106 centerline
duration at _050 221 in 230 ex
LObe seperation 112
RR in 1.6 ex 1.6
Pretty close.
Old Aug 16, 2008 | 01:30 PM
woodie582's Avatar
Thanks J, ever dyno yours...I dont have much more info on the heads. What carb are you using? I am sending my Q jet to Sparky for an overhaul.
Old Aug 16, 2008 | 08:04 PM
It's right around 390 horse. with alternator only. No PS, air, or water pump belts.
Unfortunately for you, there's no info on what was done to your heads.
Air flow in the heads is what makes your small block stand out from the others.
Look at my flow numbers compared to what the stock ones were before machining and you'll see what I mean.
Your guess is as good as mine on your motor. Sometimes mystery builds are awesome, but most of the time they're disappointing.
I'm using Holley 650 double pumper, jetted 2 sizes up.
Old Aug 17, 2008 | 01:19 AM
88 coupe's Avatar
Junior Member
https://classicoldsmobile.com/forums/40869-post3.html
Good post.
Norm
442dreamer
Jan 20, 2018 07:52 AM
HitTheHole
Nov 11, 2013 04:18 AM
tomngary
Mar 22, 2013 08:30 AM
tomngary
Mar 21, 2013 06:38 PM
tmatador
Sep 29, 2011 12:25 AM
