69 block, 73(?) heads, what gas
Old Aug 27, 2008 | 07:19 AM
KeithA0000's Avatar
69CuttyS
Hi guys. I have a new (to me) 69 350 block with #8 heads. Before I noticed the #8s, I assumed that I should use high-test gas. But with the #8s, should I be using regular unleaded? Anything else I should be considering?
Thanks,
Old Aug 27, 2008 | 08:17 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Regular gas should be fine. #8 heads have hardened valve seats.
Old Aug 27, 2008 | 08:22 AM
marcar1993's Avatar
How do you know it's a 69 block? The casting # on the timing case shelf is the same 68-76. Did it come with #8 heads? If so it's most likely a 73-76 block. 69 blocks sould have #5 heads.
Old Aug 27, 2008 | 09:17 AM
rocketraider's Avatar
Oldsdruid
Anything is possible with an engine you don't know its complete history.
If it runs fine on 87 with no detonation, no reason to run more expensive fuel. An Oldsmobile engine will let you know quickly if it doesn't like its diet.
If you get some pinging, take the plugs out, get a penlight and look down in the cylinders to get some idea what pistons are in this engine. Heads don't affect Olds CR as much as the piston dish.
Bernhard
Aug 24, 2014 09:59 AM
TicTocTach
Jan 31, 2014 10:19 AM
Magna86
Oct 19, 2013 08:53 AM
olds4life
Feb 9, 2010 08:48 AM
