67 fuel pump
67 fuel pump
My fuel pump seems to have gone bad. Zero gas getting to the carb. I am not out of gas, car is parked on flat ground and when I pulled the
fuel line going into carb and cranked it over no gas. Before I pull the fuel pump should I check anything else out? Any tips I should know of before I swap out the pump?
Thanks Matt
Thanks Matt
Make sure that gas is getting to the pump...check the rubber hoses at the tank and the splice behind the front wheel, on the frame, and of course the front hose-pipe to pump...if they are original they could have cracks which would admit air into the line...if you take the pump off, place it in a vise and manually try it to see if it will pump fluid...then you can get another one if needed...
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
mefirst72
February 10th, 2013 06:37 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
