67 Cutlass Supreme
Old Jul 10, 2020 | 12:49 PM
brianbeez67's Avatar
67 Cutlass Supreme
Hello, "rebuilding" a 330ci 4barrel, Air Conditioning car
Question- Is it recommended to change the Engine fan (clutch) if not re-installing the A/C system
Thanks Brian
Old Jul 10, 2020 | 01:55 PM
Change to what? The other stock alternative was a 4 blade fixed with no shroud. Leave the clutch fan setup and shroud.
Old Jul 13, 2020 | 06:07 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I think he means if he should buy a replacement clutch. Unless it is leaking and the engine was cooling fine, leave it alone.
Old Jul 13, 2020 | 06:33 AM
I think Eric interpreted the question correctly, which was "should I retain the clutch fan if I delete A/C?" I also agree with Eric's answer. There's no reason to eliminate the clutch fan. The fixed four blade fan draws more HP while moving less air for cooling.
turquoise67
Suspension & Handling
Jun 3, 2020 05:48 AM
keithforst@hotmail.com
Mar 19, 2018 03:09 PM
Roger60
Oct 18, 2015 02:18 PM
dukenfoof
May 19, 2013 12:20 PM
Farres74
Jun 20, 2011 05:51 PM
