swaybars 67 supreme recommendations
Old Jun 2, 2020 | 11:07 PM
turquoise67's Avatar
Hi all,
want to fit a rear sway bar to my 67 supreme 330, not sure what make or size and whether to upgrade to a matching pair front/ rear aftermarket
Old Jun 2, 2020 | 11:45 PM
Killian_Mörder's Avatar
I'd get specifications on the ones used on the 4-4-2s and match them up with any aftermarkets. I'd also make sure that the front sway bar and all four springs will also match
Old Jun 3, 2020 | 05:48 AM
You'll need to also box your rear lower control arms or buy a set of aftermarket. While your doing this project you also might as well the rear suspension bushings. Check the classified section on here I believe someone was selling a stock setup, UMI stuff is also a good aftermarket choice.
keithforst@hotmail.com
Mar 19, 2018 03:09 PM
Roger60
Oct 18, 2015 02:18 PM
Moonshineolds
Dec 19, 2013 02:11 PM
ent72olds
Sep 13, 2013 04:47 PM
dukenfoof
May 19, 2013 12:20 PM
