67 Cutlass 330/ which carb
Old May 21, 2012 | 06:05 PM
67cutlass67GS's Avatar
I just bought my 67 Cutlass 2 spd auto about a week ago, engine # 394417 & Joe P already confirmed its a 330. My question is what is the orig carb that should be run on this motor ? It has a Rochester 4B on it with no tag for ID. I found a long strip of numbers stamped in the carb body 27157 RJ 1719. If it ran fine I would leave well enough alone but the idle kinda does what it wants. Sometimes it idles great but if u leave it idle too long it feels like someone pulled off a plug wire. Going down the road low speed or highwway it runs smooth. I want to get this ride as close to bone stock as possible...And as always, I appreciate everybody's time & help.
Old May 21, 2012 | 07:17 PM
Originally Posted by 67cutlass67GS
... engine # 394417...
Is that
  • W394417,
  • W394417E ,
  • W394417G , or
  • W394417H ?
Old May 21, 2012 | 07:56 PM
Actually MD its starange. After my raised numbers 394417 about an inch or so away to the right there is a number 3 standing alone. Does that help ? Thanks again for the help..
Old May 21, 2012 | 08:26 PM
Oh. You menat the block casting number, not the engine number.
The engine number is stamped onto the front surface of the passenger side head (or the back of the driver's side, if it's been apart...).
Old May 21, 2012 | 08:37 PM
2blu442's Avatar
Welcome to the site! Let me throw some pictures up for you to check out. That number sounds right for a 1967, but here's two different ways quadrajets had the numbers on them. The first is off a 1966 and my 1967 Cutlass has the same round disc for the number. The second one is from a 1975 and I know this method was used in 1968 and it sounds like what you've got.
Next, the engine number you've posted is the casting number between the water pump and intake, like this
But the engine number that Eric is asking about is stamped in the front of the head, like this 1966 330 engine.
Also... in another thread you mentioned you have C heads which would be correct for a big block. Here's a couple pictures of where the 330 head should have a large 4 cast into it, while the 400, 425 & 455 would have the letter C in the same location. This casting would be on the drivers side to the left of the front most spark plug and the pass side next to the firewall.
So if you haven't figured out yet I like pictures... much easier to communicate and I've got the clutter of Olds parts to go through for the pictures. John
Old May 21, 2012 | 08:38 PM
well i also found numbers on the back of the left
head near FIRE WALL V488070 G THE STAMP IS INJ THE B ACK OF THE HEAD FACING THE DRIVERS SIDE..
Old May 21, 2012 | 08:41 PM
wOW GREAT PICS, I LIKE THEM TOO..lOL Pictures speak to me in so many ways.lol. Tomorrow i will cleanm of the front left bank of that head, its easy enuf to get too. The other head number came from behind the head closest to the firewall facing the steering wheel...
Old May 21, 2012 | 08:43 PM
2blu442's Avatar
That just means someone put the head on with this end facing the firewall. Not a problem as long as you have the holes to mount the alternator or AC compressor, etc.
But this tells us you have big block heads on a small block. From what I've read, that will drop your compression. So you may want to swap the correct heads on it, or upgrade to a big block. Also I believe the head code you mentioned is correct for a 1967 400 engine in a 442. So if you don't use that it will be a nice trade stock item.
Can you see a large letter C cast next to the spark plugs on your heads?
Old May 21, 2012 | 08:47 PM
wow 2blu thats been a hyge help for sure.../See pictures do work, they say thousands of words..I will check on those letters in those locations...I appreciate all the help,,,
V••••••G is a 442 number, though I didn't think they went all the way up to 4••,•••.
Are these B or C heads? Because big block heads on a small block motor would not run well without modifications.
edit: Gee, John, you beat me to it .
Old May 21, 2012 | 08:52 PM
2blu442's Avatar
At least we're saying the same thing
hell no I guess they wouldn't....LOL That right side head stamp clearly said V488070 G & IT WAS ON THE BACK OF THE DRIVERS SIDE HEAD..
Old May 21, 2012 | 08:59 PM
well i do agree that my research tells me about them being for a 400, that led me to thinkingh that i may have a 400 but the engine numbers say different 394417 3 exactly how it looks. And the car is a dog off the line,,
Old May 22, 2012 | 08:19 AM
Cool
I didnt even know that there would be other numbers as your pics show. Well this is good it gives me a great reason to pop the hood on old Rosie & look for head numbers while drinking coffee...All of your help is greatly appreciated..I will also try to get some closer pics of these area's...I looked again & cleaned it up better. My numbers/letters may be a W instead of a V, the number now looks like W483070 C & the end letter now sure looks like a C that i thought was a G. very rusty & not stamped real deep, im also looking through a mirror. I appologize for the run around..Also at the number 1 & 8 cylinder there is a raised # 4.......Thanx for everyones time.
Old May 22, 2012 | 09:10 AM
Carb that is currently on the car...Thanx
Old May 22, 2012 | 09:16 AM
W483070G (there was no "C") is a 1967 4bbl 10.25:1 330.
#4 heads are correct for that motor.
So that's one mystery solved.
Old May 22, 2012 | 01:20 PM
Alright ! Thanx a million MD....Sounds better to me but i have one more question. LOL..I would think that a 330/320 would have more oomph to it, it may be becuz its a heavy boat or maybe the carb is not doing its job.. I have to say this thing is slowwwww...Cruises at 80 on the highway beautiful so i cant complain. She is probably tired too..I know I am & im a little older then old Rosie is...Thank you again..
Old May 22, 2012 | 02:06 PM
Oldsmaniac's Avatar
Carb appears to be era and possibly the original. I would try and rebuild that one first.
Old May 22, 2012 | 02:30 PM
Thats exactly what I am going to do, rebuild time...Thanx, Olds maniac
Old May 22, 2012 | 08:25 PM
BILL DEMMER's Avatar
Just the facts...
carb. number is correct, but the date code indicates that it's a 1969 factory service carb. the original carb. would have the round tag with the number, not stamped in to the carb. body, and the date code would not be 1719
bill
Old May 23, 2012 | 04:28 AM
Smile
bill
O.K Bill, it's very much appreciated. If thats the case I'll stick with it & do the rebuild & hope that the idle stops changing its mind whenever it decides too. Starting to remind me of my Ex wife..Have a great day..
Old May 23, 2012 | 07:44 AM
Just the facts...
you may have worn throttle shaft bores. after you clean it all up nice, check for slop. if excessively worn, you're going to want them bushed.
bill
Old May 23, 2012 | 09:23 AM
Cool
[QUOTE=BILL DEMMER;409180]you may have worn throttle shaft bores. after you clean it all up nice, check for slop. if excessively worn, you're going to want them bushed. Thanks Bill for sure something I will check. Other then the idle changing here & there mechanically it runs awesome. Ive only had her a bit over a week. I will say that old Rosie as I call her tunrs lots of heads. I hate that. LOL ! NOTTTTT>>
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
gthmcty1
Jun 12, 2009 01:12 PM
The_Jeremiah
Dec 4, 2007 06:22 PM
thomaswatk
Mar 22, 2007 01:31 PM
