66 cutlass 330
Old Jun 26, 2012 | 06:07 PM
Kevin2's Avatar
66 cutlass 330
I've been working on getting this cutlass in road worthy condition for about a month now but I can't seem to get it running right. The engine runs strong at idle in park but when I put in in gear it idles rough. Also acceleration after a stop has to be slow and even otherwise the engine trys to stall. Anyone know what the problem could be? Thanks in advance.
Old Jun 26, 2012 | 06:24 PM
What are your tuneup settings? Is your trans still a Switchpitch Jetaway, and is the switch and rest of the system operating correctly?
Old Jun 26, 2012 | 06:52 PM
Kevin2's Avatar
To be honest I'm not exactly sure what transmission is in the car, but I'm pretty sure it is the original. As far as tuning the only thing I've adjusted id the idle mixture screw. I haven't found any other adjustment screws.
Old Jun 26, 2012 | 06:56 PM
How are your cap, rotor, and wires?
Maybe you should spend some time reading the Chassis Service Manual, and get back to us after that with some specific questions.
Old Jun 26, 2012 | 10:43 PM
64Rocket's Avatar
Like what was said, check your cap, rotor, points, plug wires, fuel filter, fuel pump pressure, and most of all check your timing.
Get a shop manual and start reading.
Gene
andrekbelo
Sep 2, 2008 04:25 PM
olds382
Aug 14, 2008 10:08 AM
Mr. King
Dec 12, 2007 05:47 AM
nevadacutlass
Oct 8, 2007 07:28 PM
dalvlageinc
Jun 13, 2007 02:39 PM
