65 rochester
Old May 5, 2013 | 12:24 PM
lilhow's Avatar
65 rochester
Hi everyone I am rebuilding my carb which is a 65 rochester 4 barrel. I was hoping someone would know if the bearing in the bottom of accelerator pump is suppose to come out. It looks like it does on the exploded view but mine will not. thank for any info Jeff
Old May 5, 2013 | 08:15 PM
BILL DEMMER's Avatar
Just the facts...
do you mean the check ball in the bottom of the accelerator pump well? yes, that is supposed to come out. there may be a retainer ring holding it, but you should be able to see the retainer ring. if the ball is stuck, spray a little carb. cleaner in there and tap the ball with a 1/8" drift. it should fall out when you flip the bowl over. if you know which passages are for the accelerator pump discharge, cover one of them, and blow air into the other one(don't have your face above the bowl when you do this... think bb gun). i haven't played with a 4G in a quite a while, this is just from memory.
bill
Old May 10, 2013 | 06:23 PM
lilhow's Avatar
thanks Bill had to knock out plug but got it out. Check ***** were reversed that is how it got so jammed in there. May have done it myself 20 years ago don`t know how it ran this long.
Old May 14, 2013 | 10:03 PM
Just the facts...
glad i could help, yw.
bill
opelitis6
Jan 17, 2008 04:26 PM
ViceGuy
Mar 25, 2007 01:43 PM
emarkay
Dec 8, 2004 08:23 AM
