65 cutlass 330 issues
Old Aug 14, 2008 | 08:21 AM
olds382's Avatar
I have a 61,000 mile 65 cutlass with the High compression 4bbl 330 and 2 speed auto. I have 3 problems I've been working on all summer.
1. The car does not seem to have the pick-up that I believe it should have (Even with the 2 speed auto) I can hardly spin the tires. I am running the timming at about 10 degrees advanced of the factory setting, and put a Pertronix points replacement system on it.
2. The car has an idle that is not real bad, but I notice a roughness when it's warm.
When I blip the throttle after it has idled in line at the Dairy Queen to try and smooth it out, I get a little blue smoke. I do not notice this on start-up. I have been adjusting the 4jet back and forth all summer. I also noticed this week that it has a cracked passenger side exhaust manifold.
( could this all be a poorly adjusted carb )
3. The other day I floored the accelerator from a stop. The engine seemed to rev higher then normal before shifting (guessing 5800 plus RPM)
When I returned home and opened the hood, It looked like oil had come out of the oil fill tube. I could not do a leakdown test, But a compression test showed 155 to 165 compression in all cylinders.
This is my first post.
Any and all opinions would be appriciated.
Thanks in advance,
Rob
Old Aug 14, 2008 | 10:08 AM
The first thing you should do is remove that cracked exhaust manifold and have it repaired. It might not be anything more than a minor exhaust leak but you will need it fixed eventually. Take it to a good welding shop to have it repaired.
I also suggest doing a tune up. When was the last time you looked at your cap, rotor, timing, and carburetor settings? This will at least put you at a base line that you can work from.
You might also try to find a way to do a leak down test on your engine. You might be loosing oil through your valve guides if you get a puff of blue smoke every time you start the car. This is cured by having the heads machined.
1965F85_scholten
Jul 13, 2013 02:57 PM
sixtyfour
Jul 10, 2013 09:39 AM
FIJIBLUE72
Body work
May 6, 2009 04:58 AM
cutlassdriver61
Feb 6, 2007 05:52 PM
macarthur
Jul 25, 2006 12:46 PM
