55 & 56 Pushrods; hole or No hole ?
Old Nov 29, 2024 | 01:19 PM
rocketman8's Avatar
Hi Guys, on the 55 & 56 pushrods; which year is solid & which year is hollow ??? Thanks !!!
Old Nov 29, 2024 | 06:05 PM
Charlie Jones's Avatar
Phantom Phixer
As far as I know all Olds pushrods before 1965 were solid. (except F-85 ).
Oil to the rockers was supplied by internal passages in the block and heads.
There were several different push rods used through the years, as seen in group 0.426 below.
Old Nov 29, 2024 | 09:35 PM
rocketman8's Avatar
What are the 2 grooves and 4 grooves meaning ??? Thank You !!!
Old Nov 30, 2024 | 08:16 AM
Phantom Phixer
My guess would be that the OEM pushrods were "grooved" somewhere to identify them.
You'll note that the pushrod lengths are given. Try to find rods that are as close to the length for your application as possible.
Allow .020 leeway and you should be OK.
Aftermarket pushrods available today, have a solid ball electro welded to a tube.
They are spec'd for '52 to '64.
Old Nov 30, 2024 | 08:23 AM
rocketman8's Avatar
Thank You !!!!!
54Rocket
Nov 26, 2024 09:50 AM
fatfarms792
Dec 2, 2017 08:01 PM
fatback
Aug 22, 2016 07:34 AM
burnout-dave
Nov 14, 2011 03:37 AM
hialeah56
Oct 25, 2009 06:02 PM
