'55 324 Rebuild
Old June 24th, 2013, 01:33 PM
fuxl's Avatar
'55 324 Rebuild
Started this rebuild over a year ago, and I'll post my progress on here, if there is any interest?
The car in the back ground is what it going in.
fuxl is offline
Old June 24th, 2013, 01:39 PM
59-59-59's Avatar
Yes! Finally not something out of a Cutlass/442
59-59-59 is offline
Old June 24th, 2013, 02:24 PM
car guy
gearheads78's Avatar
I would like to see what you are doing. Post away.
gearheads78 is offline
Old June 25th, 2013, 05:13 AM
fuxl's Avatar
Alright then, here we go...
Of course the engine was stuck, and if you've worked on these engines before, you know that you can't get the transmission unbolted, if you can't turn the crank.
So the first objective was to get it unstuck.
Let the party begin:
Heads are off and I'm already fearing the worst.
That's right, non detergent oil, and very few oil changes is what turns into this:
Can you say sludge?
fuxl is offline
Old June 26th, 2013, 11:21 PM
Hot Rod Has Been
krooser's Avatar
Pretty normal looking sludge back in the 50's-60's... the early engines are great platforms... you keeping the Hydro?
krooser is offline
Old June 27th, 2013, 05:51 AM
fuxl's Avatar
Well, this engine came with the early hydro, but the car has a Jetaway, so I adapted the crank to use the Jetaway.
So then I started treating the cylinders to get it unstuck:
Externals came off real easy. Didn't break a single bolt.
When I drained the oil, it seemed like there was more water then oil in there.
The distributer was kind of a pain to get out, since the cam didn't turn, and all the sludge didn't help...
I build me a tool with 4 foot extension, to break it loose, and I could finally take the hydramatic off.
Then I could put it on the engine stand and work the crank out.
That was one big event. I thought it was never going to happen...
fuxl is offline
Old June 27th, 2013, 01:24 PM
citcapp's Avatar
Looks like fun. Don't get your hands dirty now
citcapp is offline
Old June 28th, 2013, 06:17 AM
fuxl's Avatar
Don't worry, it's too late for that
In the meantime, I started tearing the heads apart.
Just the right amount of brute force, and they would cooperate...
So then I was able to drop everything off at the machine shop, to get it checked out.
Little teaser, intake mock-up.
fuxl is offline
kaptmikey
November 27th, 2012 10:49 AM
Russ P in MD
April 24th, 2012 10:40 PM
442dreamer
August 23rd, 2011 07:28 AM
Gary's 2 442-S
August 14th, 2011 12:04 PM
442oldslawyer
April 29th, 2010 09:22 PM
Quick Reply: '55 324 Rebuild
