55 324 rear main seal leak
uggg dang it, all that work, now I see the rear main has a leak in my 55 324, guess I should have replaced it before installing the engine, is it possible to change rear main seal without pulling the engine, I know on a chevy s/b you can, my luck its not, Thanks
Thanks Ozzie, I did see that in the manual, but didnt know it could be done without pulling the motor, this is good news, mechanics at my shop said give it a bit, the rope seal may swell now that the motor is running as it has sat along time, guess time will tell, at least now I know I dont have to pull the motor, thanks again
It can be done, (had mine done that way last time also) but you have to be some kind of contortionist, you flat run out of room between trying to get the pan out of the way ,which if I remember correctly can't be removed completely and then drop the crank enough to slip the top half of the main seal in (I used a neoprene seal) very tight quarters.I don't do tight quarters anymore but my friend who is very talented said lets not do this again....Tedd
