Vacuum advance on a 83 H/O
Old Mar 6, 2015 | 05:37 PM
truckerlary's Avatar
My 83 has a vacuum advance on the distributor and I was wondering if this is correct for an 83 or has someone changed it out. It is a HEI unit. My manual says it should be with electronic timing after 81.
Old Mar 6, 2015 | 06:34 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Even in Canada, they came with electronic advance, isn't factory. What carb is on it?
Old Mar 6, 2015 | 07:13 PM
It has 17084287 quadrajet which I pretty well know isn't right for this car. Also has a performer manifold on the car. A previous owner has removed and the emission equipment from the engine. Still has the computer in the car but not sure what is left for it to control. Really would like to know what the carb came off of. Larry
Old Mar 6, 2015 | 07:48 PM
Shows to be from an 86 Olds 307, Rochester 4 Barrel R4-M4MC; w/Open Loop (no Solenoid on Air Horn).
Old Mar 6, 2015 | 07:55 PM
So will it be alright on my 83. What job does the solenoid on the air horn do. Is this the solenoid I'm looking for that bumps up the rpm when the air comp. kicks on?
Old Mar 6, 2015 | 08:15 PM
No, not the same solenoid. I believe you have a non CC carb, and a standard HEI, with no emissions remaining as per your description. So I assume the engine basically runs like a like a pre-emission, non CC - V8. Some of your problem may be that your timing is too low, it's normal to set the engine a bit higher in rpm to account for the additional load of the compressor, if your timing is too low then the rpm drops considerably more with the load.
The part you need for your a/c is an Idle stop solenoid.
Old Mar 6, 2015 | 08:21 PM
I found a used idle solenoid today and mounted it on the carb but it didn't have enough oomph to push the throttle lever. Guess I will keep looking. Thanks for all the info. Larry
Old Mar 7, 2015 | 06:35 PM
Pretty sure even Canadian cars came with CCC carbs 86 and up, was optional before that. Just make sure there isn't a blue electrical connector on the passenger side front of the carb or it will run pig rich. Make sure your base timing is set at 20 degrees.
pcard
Feb 11, 2013 05:09 PM
Redog
Jun 21, 2012 08:05 AM
88 coupe
Jul 31, 2008 08:54 AM
88 coupe
Mar 14, 2008 11:16 PM
harleyrules
Nov 16, 2007 05:27 AM
