#5 main cap sealant?
Old Mar 10, 2015 | 08:25 AM
SkylinesSuck's Avatar
I am replacing the rear main seal with a 2 piece neoprene job and looking at the FSM. It calls for some type of sealant on thr main caps themselves. What is this and do I need it?
Also other kinda related question; plastigauge measures between .003 and .004. Leave it alone and button it back?
Old Mar 10, 2015 | 08:43 AM
pogo69's Avatar
morgan
you should use a dab of rtv at the joining areas of the rear seals to help prevent a leak and also offset the seals in the block about a 1/4 inch
Old Mar 10, 2015 | 08:47 AM
pogo69's Avatar
morgan
.003 - .004 on rear bearing 5 is ok....on the others thats a little loose but not terrible there is more of a risk of failure at that higher number on 1-4
Old Mar 10, 2015 | 09:27 AM
Octania's Avatar
I recommend some sealer OTHER than RTV which can and does ooze out and make strings that break off and go elsewhere.
Form-a-Gasket #2 non-hardening
Permatex 3H aviation sealer
Yamabond at your Yamaha dealer
are some good choices.
Old Mar 10, 2015 | 09:45 AM
pogo69's Avatar
morgan
i will agree there are other sealants you can use as above... rtv is sometimes tricky to use you want a thin consistent one piece bead....not blobs of it that can shred
Old Mar 10, 2015 | 09:46 AM
Great info, thanks. And just to be clear, I am not talking about a dab of RTV on the ends of the neoprene seal. I know I need that. It seemed like the fsm wanted some sort of sealant on at least a portion of the mating surface of the cap/block itself.
Old Mar 10, 2015 | 09:53 AM
pogo69's Avatar
morgan
yes i was also referring to that also ....running a bead down each side of the ridge in the block side to completely seal the cap
Old Mar 10, 2015 | 11:51 AM
You're talking about the sealing surface between the #5 main bearing cap and the oil pan, right?
Because, just to be clear, there is no sealant used between the bearing caps and the block, or between the oil pump and the bearing cap.
Old Mar 10, 2015 | 04:48 PM
Old Mar 10, 2015 | 05:05 PM
pogo69's Avatar
morgan
that sealer is similar to the aviation permatex ....that is the ridge i was referring to ( on the block) i just happen to use a bead of rtv along both sides as in the pic
Old Mar 10, 2015 | 05:52 PM
You mention a ridge; I see a little valley on the cap that is also pictured in the FSM. Is that what you mean? It ison either sideof what I'm guessing is where the thrust collar rides. It looked like there was some type of sealant in there when I pulled the cap and I have since cleanedit out with a razor.
Old Mar 10, 2015 | 07:13 PM
pogo69's Avatar
morgan
Ok ridge is confusing i bead the area on far rear lenghth of the block
where the cap butts to the block the bead starts at the seal end and back a little then across
Al2011
Aug 27, 2025 08:30 PM
at3reg98
Nov 15, 2013 07:51 PM
smietana
Oct 31, 2013 12:21 AM
Al2011
Mar 11, 2013 08:04 PM
krooser
Jan 17, 2013 10:15 PM
