455 in a 65 A body
455 in a 65 A body
Iam replaceing the 350 in a 65 cutlass with a 72 455 what would one run into doing this? I know the wiring for the starter needs lenthen as the starter is on the passenger side on the 455 and is now on the drivers side on the 350. what about mtr mounts? has any one did this swap? thanks ...jim
The starter on the 455 is in the same location as the starter on the 350. It is a straight foward install use the motor mounts from your 350 and it will bolt right in. If you are keeping the turbo 350 tranny you don't need to make any changes on there but you will need to have the tranny built to handle the extra torque of the 455. If you use a turbo 400 there are other revisions required to the rear tranny mount and drive line. check the big block and small block sites there is lots of information on this subject use the search engine
Not 100% on the converter but the headers will not work at all. The taller deck height on the 455 requires a BBO header.
OK, went and looked at the 455 and its starter is on the drivers side, Iam using becool 4 row alumi radiator and have front springs for a/c equipt car on the car now for header clearance, wow headers cant be used! well thats one for solving .the exhaust manifolds on the 455 pass side has two outlets one for the cross over the other for out the rear. kooks hum!
For exhaust, consider the repro W/Z manifolds as an alternate to headers.
so all in all purchasing a set of manifolds to replace the headers, thank heavens, dont like headers and possibly the convertor am ok with this swap. will the 400 convertor work with my 350 trans?
I know its been a lot of questions but Ilike to have my ducks in a row, besides the torque convertor will there be any hood clearance problems and will my eldelbrook 600 cfm be ok?
You need to know what year the TH 400 is. I'd tell you to look for two wires where the kick down connects, but that isn't always a giveaway. Some (like my car) have an advance retard system that uses the trans and vacuum so there is an extra terminal on the trans for it.
The Qjet should work for you. It may need to be re-calibrated or even rebuilt depending on condition.
need to know what will transfer from a 350 to a 455, valve covers, oil pan, short style water pump and joe p stated the am to transfer the pullies and brkts from the 350 to the 455 as they are the single grove pullies, also am to transfer the mtr mounts from the 350.
All of the above. Good luck
Use all of it.
jensenracing77
Drivetrain/Differentials
May 17, 2017 07:39 AM
