45 degree cam in 350 ?
Old Jun 11, 2008 | 10:04 AM
DennisG.'s Avatar
Would this work and just how bad would it run ? I just picked up a Cutlass. It`s set for a few years. I`m working on getting it started. I have a bunch of reciepts from when the 350 was rebuilt. What bothers me is the cam card states it`s for a 45 degree 330-425. The motor was done back in 84 so it`s definately been running. I`m just wondering what effects running a 45 degree in a 39 degree block will have on the way it would run and perform ?
On another note. It`s a Crower M-280-H Monarch. Part # 56150. I had one of these before in a 350 and it screamed. I still have the cam card from that. Same cam, grind number etc. But the specs are different on both.
Old Jun 11, 2008 | 10:47 AM
Well, the 45 deg bank angle means that the lobe centerlines from bank to bank are 90 deg apart. On a 39 deg cam, the lobe centerlines are 78 deg apart. If the cam was installed without indexing, then the LH bank is probably 6 deg retarded and the RH bank is probably 6 deg advanced. The options range from there - it the cam was degreed on the No. 1 cylinder, then that bank is probably right on and the other bank is 12 deg advanced.
You say the engine has been run - but for how long? I would imagine that it runs like crap. Possibly the P.O. started it, couldn't get it to run right, and parked it.
Old Jun 14, 2008 | 12:18 PM
DennisG.'s Avatar
I have no idea of how many miles are on it all I know was it was redone back in 84. I have no idea of how long it`s been actully setting. I got it started today. It runs like crap. I have to get the old Holley off there and get a good carb on to tell how well it`ll run. I have other cams to put in it if I need to. I was just wondering if anyone had any experiance with this type of foul up.
hotrodpc
Jun 21, 2021 06:38 AM
boondocker
Dec 22, 2010 02:35 PM
nickd
Aug 18, 2009 02:36 PM
scrappie
Jul 22, 2009 03:11 AM
rt38 classic engines
May 9, 2006 05:28 PM
