403 solid web mains myth or real ?
So, I tried to search for a thread on this but failed to get where I am pretty sure there is already a good discussion about this. In fact it seems to me I read something Joe P posted some time back about this very topic. So here goes:
Was there any 403 blocks cast with solid web main bearings. I have never seen one and believe there is no such thing. What is the truth?
Thanks guys
Larry
Thanks guys
Larry
Thanks guys
Larry
Thanks guys
Larry
Chris has been offering that reward since the 1990s, back on the old Chubecto listserver Olds site. As noted, not a single SMW 403 has ever been documented since they were first cast in 1976 (for the 1977 model year). Keep in mind that EVERY SINGLE gasoline Olds V8 block got windowed mains starting with the 1977 model year. It would not surprise me if prototype 403 blocks cast in the mid-1970s as part of the development program were based on the older solid mains architecture, but even if they were, none were ever installed in a production vehicle (and none have ever been documented).
The article I posted did talk about 2500 of them being produced? Click the link and scroll down a bit.
Those do show up from time to time. There has never been a documented SMW 403.
Yeah, sure, 2500 were produced yet not a single one was cashed in for a $1,000,000 reward (that's one million dollars), or even simply photographed.
Let's put this in perspective. There were 54 1966 W-30s built and a large number of them still exist. There were three 1969 H/O convertibles built, and two are still known to exist (one was destroyed in an early crash). Out of 2500 alleged SMW 403s, NOT ONE has ever been photographed or otherwise seen in public. Does that seem plausible to you?
Keep in mind that every single gasoline-powered Olds V8 block used windowed main webs from the 1977 model year forward. I suspect that there were some solid web 403 blocks cast during the early development in the mid-1970s, since all Olds V8s were SMW at that time. The problem is, even it that were true, those were experimental engineering development units that did not get released to the general public. In over 40 years, not one has surfaced. I'll point out that other experimental parts HAVE surfaced, including the cross ram and Webber intakes I have for the BBO, aluminum heads and blocks as used on the CroSal Can-Am race cars, and a TBI intake for a 307. Still no SMW 403s, however.
As I posted earlier, I have several of them, 4.015" bore, 3.975" stroke. Originally they were 400 E blocks, but were bored .015".
If anyone had "real" SMW 403 blocks, it would likely have been Vance Brady, but none surfaced after his death. You will have more luck finding a NASCAR block, and a few of them have been found.
I can give you one firsthand data point. Using the finest Chinesium bathroom scale sold by WalMart, I weighed a bare 455 block and a bare 403 block. Yes, I am aware that this is a BBO vs SBO comparison in addition to a SMW vs WMW comparison. The 455 block was exactly 200 lbs. The 403 block was exactly 170 lbs. I'd guess that the deck height difference was maybe half of that 30 lbs.
I picked up a 403 block from a 1977 TA - Might be SWM
I bought a 78 TA without an engine, and the same day saw a 403 from a TA for sale on Craigslist. Guy said his son looked at the numbers and thought it was a special block - said there was only 1000 built. I didn't think much of it. I just needed an engine. I looked at the numbers it is 554 990 4A. the heads have the 4A on them also. Wont get exited until I open up the OP and look. Will update.
As I recall, Joe Mondello started this rumor about the 2500 SMW 403's. His first technical manual mentions these being produced in Buick wagons and Firebird Transams. Never seen one and never will.
#32
Nasty455
April 9th, 2012 11:06 AM
