Maybe it's a Myth
Old May 26, 2013 | 12:02 PM
jpc647's Avatar
Maybe it's a Myth
I was told, and have read before that all 68-72 Cutlass's are prewired for certain accessories regardless of whether the car was ordered with them or not.
For example, the clock. I went to put a standard clock in the car this morning, and I can't find the wires tucked back in the dash anywhere.
Car is a 1972 Cutlass S, factory bucket/console car.
Old May 26, 2013 | 02:17 PM
ALL cars made come with the connectors pre-installed in the harness for options. Your clock feed is there. Keep looking. There should be an orange wire with a single connector that's on the same circuit as the cigarette lighter.
Old May 26, 2013 | 03:00 PM
Lady72nRob71's Avatar
They were prewired for only some minor options; your clock is one of them. You should also find a gray wire for the clock light back there somewhere...
Major options like cruise, power windows, seats, trunk, got their own wiring harnesses.
Old May 26, 2013 | 05:14 PM
What about the tach for '68?
Old May 26, 2013 | 06:57 PM
The Tic Toc Tac uses the same orange and gray wires as the clock, but has a separate harness (just a single wire with a fuse if I remember correctly) that connects to the negative side of the coil.
Old May 27, 2013 | 05:25 AM
oldspackrat's Avatar
The power wire for the trunk light is there also. It is located just to the left of the left side trunk hinge. I believe the power wire is there also for a power driver seat. It is a large orange wire located in the plastic loom under the seat in case any one wanted to know.
Old May 27, 2013 | 07:21 AM
No electric seat pre-wiring in my 72. That might be true if the car came with power windows or such...
lemoldsnut
Apr 11, 2018 10:34 AM
Rocketguy
Oct 29, 2014 01:19 AM
Wildcard
Dec 5, 2012 06:40 PM
norrloader
Jun 5, 2006 06:44 AM
grandmas73rocket
Nov 23, 2004 04:51 AM
