403 Cyl head frost plug
Old October 31st, 2009, 02:51 PM
abram's Avatar
I have a 403 installed finally into a 1977 Silverado, which has a leaking frost plug on the passenger side cyl head, how tough are these to change, Ive never done one before, any ideas?
Al
abram is offline
Old October 31st, 2009, 03:15 PM
dan2286's Avatar
Being on the head, it should not be that bad. I am assuming you have plenty of room to work since it is in a truck. What I would do is take a brass punch or something else that won, punch through the freeze plug and try to hit it so it flips the plug sideways so you can grab it with some pliers and pull it out. Try not to knock it all the way in the head. Use a brass plug to replace it.
dan2286 is offline
Old November 2nd, 2009, 11:02 AM
abram's Avatar
Took some doing but I got the old one out and picked up a expansion type from the local parts store, should be good to go!!
abram is offline
455cutlass1969
April 24th, 2014 01:56 PM
ds00469
January 25th, 2014 05:12 PM
tnelson
February 7th, 2011 06:46 AM
OldsManNJ
November 17th, 2010 11:47 AM
68conv455
January 12th, 2010 03:39 AM
Quick Reply: 403 Cyl head frost plug
