403 in a 1977 Trans Am question
I am looking to replace a dead electric fan set up with a fan blade and clutch. I thought I would ask here first because there is more knowledge and willingness to help here than other forums. I need to know what I am looking for. I believe the fan can be six or seven blade, possible 19 or 19.5 inch diameter, measuring the shroud somewhat confirms this too. I do not see any aftermarket fan blades. I do see aftermarket short and factory height fan clutches. It is an AC car. Hopefully someone here can answer. TIA
Summit has a vast selection of Fan blades though not sure which of these will work in your application.
This Pontiac vendor lists a 17" fan for 67-79 Firebirds.
Summit also has a selection of Fan shrouds (Summit says this shroud fits a 77 TA with a 403)
I think you should be able to get everything you need from either Summit or one of the Pontiac vendors. My recommendation would be to get the dimensions on the shroud (if possible) and then order the fan based on that.
Looks like a 19.5" 7 blade clutch fan.
https://www.ebay.ca/itm/194798508630...mis&media=COPY
72GoldOlds350
Apr 25, 2020 12:59 AM
