Anybody using a Street Demon spreadbore?
Old May 1, 2022 | 12:51 PM
James J's Avatar
Hey guys, wondering if anyone had one of these on their Olds in place of a Q Jet. I got an 84 H/O and was wanting to put the 625cfm on it. Was planning on building a 350 later which would probably be better with a 750, I wonder if the 307 could use the 750 in the mean time.. I know the Q Jet is a 750-800 but it has a limiter on it to keep the secondary's from opening all the way on the 307. It's also got a TPS kit available. so the trans will lock up. Thanks Jackson
Old May 1, 2022 | 01:10 PM
danktx's Avatar
I have a model 1904 750CFM on a 455 in my 67 CS. Driveability is good. Easy to setup. I bought mine as a factory refurb and they split the gaskets by over torqueing the screws during assembly.
Old May 1, 2022 | 04:46 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The 750 should work. You will need a tuning kit, both the 625 and 750 cfm will be rich, out of box. Get a wideband, you have a factory O2 port. Then you can get the tune spot on.
Old May 3, 2022 | 09:43 AM
acavagnaro's Avatar
I run a 750 on a slightly modified '60 400G. Have had it for ~5years with no complaints. Performs as well as the original Q-jet did. I've always tuned it with a vacuum gauge although a wideband is the best way to go.
Old May 15, 2022 | 06:56 PM
JohnTN's Avatar
I have a 625 Street Demon on a mild 350. It was too rich out of the box and only got 14 mpg. I leaned it out with leaner primary rods and jets by about 20% and fuel mileage increased to 18 mpg. Has been functional with no issues for 5 years. You can search my posts for more details on the rods/jets.
John
James J
Hurst/Olds
Apr 30, 2022 06:58 PM
SuckasHateMyNinetyEight
May 9, 2021 07:22 AM
Dink5858
Aug 7, 2020 04:52 PM
carbonf00tprint
Nov 4, 2012 07:53 AM
307Cutlass87
Dec 2, 2008 10:33 AM
