307 to 350 swap
Old Aug 6, 2020 | 06:22 PM
Dink5858's Avatar
307 to 350 swap
I’m new to Oldsmobile. I just brought an 84 delta 88 with a 307 in it. I want to buy a crate 350 from autozone but it the diesel one they trying to sell. Is there another olds I can get a gasoline 350 out of to fit. And what is a good transmission to get to put behind it?
Old Aug 6, 2020 | 06:44 PM
rocketraider's Avatar
Oldsdruid
Olds made gas 350s from 1968-80 and any of those are pretty much a drop-in. Found in 2 and 4 barrel versions in Cutlass/F85, Delta 88s and 70s Omegas. 68-75 are better; later ones have windowed main bearing webs. Use the accessory drives from the 307. You will probably want to run it off-computer but 350 can be adapted to the C3 system.
I would personally get the 200-4R trans built to take the 350. It has good gear spread and OD.
Old Aug 6, 2020 | 06:47 PM
69CSHC's Avatar
Welcome aboard Dink,
1968-1980 Oldsmobiles are the years that may have 350s in them. 1968-1976 are considered the best years. Later years can also be found in other car brands.
Your gonna likely want a THM350 as the transmission to go with it, which shouldn't be too hard because that was the most common factory pairing.
Old Aug 7, 2020 | 04:52 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You can still find good running mid 70's Olds 350's. The 71 to 76 motors are good but have 8 to 1 compression with the same cam as your 307, only a modest improvement over your 307. Don't overlook a 403 if a good runner can be found, again 8 to 1 with the same cam but more torque. I agree, do a shift kit and remote cooler on the stock 2004R trans, also consider a rear gear swap as well.
Oldsboi
Feb 12, 2018 05:37 AM
Amarion58
Feb 23, 2017 11:16 AM
deltaroads
May 14, 2011 08:54 AM
gscott819
Feb 8, 2009 04:06 PM
olds307owner
Jul 28, 2007 06:29 PM
