400 vs. 403
400 vs. 403
In my search for a motor to give a mild build-up and replace my original 350 (I want to race the car once in awhile and not worry about blowing up the original engine), I've come across two recent classified ads; one for a 400 BBO and the other for a 403 SBO. The details:
400 ---> • out of a '68 442. • rebuilt less than 6,000 miles ago. • mild cam. • making the "original" 365 hp. $750.
403 ---> • out of a '79 Trans Am. • runs excellent. • has aluminum intake. • $350.
Any opinions on the better selection? I know about the 403's windowed mains, paper-thin cylinder walls, etc., but I like the idea of a shorter stroke and a motor that'll drop right in the car while breathing alright through the 2.25" exhaust. What would the 403's compression be if I put my #5 heads on it?
- GoldOlds
- GoldOlds
^^ I could have bought a 400 without carb, mani, exhaust manifolds and valve covers with the orginal tranny for $300, but it was too much work. The one I got was running, but I updated it (carb wise) ![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
I guess it depends on your plans for the car your putting it in, if's it's just a cruiser, I'd say got for the cheap one, but why is it so cheap
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
The 403 will work fine, and as you say it bolts right in. Cr with the #5 heads should be around 8.5, but there are a lot of determining factors. That is a "late" 400, long stroke engine. The "early" 400s were screamers, short stroke, big bore. I would not go to the trouble of going the big block 400 in this case.
I'd go with the 403 as the long stroke, tiny bore 400 is not Oldsmobile's best design. I don't understand this comment however:
Both engines will flow the same amount at the same RPM, so what difference does this make? If you're referring to the exhaust manifolds bolting up, the flanges on big blocks and small blocks are in the same position relative to the crank centerline (which is why W/Z manifolds won't fit a small block). Neither engine will breath adequately through 2.25" pipes.
You won't have to worry about blowing up an Olds engine. Especially if you are just doing a mild streetable rebuild. If you start asking about hi compression pistons, solid lifter cam shafts, hi volume oil pumps, and double rolling timing chains then you should start worrying about blowing your engine. Not to say that double roller timing sets, and hi volume oil pumps aren't good additions to a streetable engine, even if they are overkill.
- GoldOlds
BTW, thanks everyone for your input!
I'm with Olds64, build the 350. It is extremely durable, you have the best 350 Olds made, and you already have it. I run high 13s in a mild 9 to 1 355 wagon with 3.42 gears. Driven daily. Bump the Cr up to 9.8 or so, a little more cam, you already have the gears, 13.5s should be easy. Here is a link to my combo if you want the specs.
http://72.22.90.30/phpBB2/viewtopic.php?t=28012
Again, thanks for the input! I guess this could be one of those cases where the solution may be sitting right under my nose (or should I say "hood") all along. When a set of SBO heads are milled, do I . . . A) have the pushrods shortened the exact same amount B) install roller tip rockers or C) both A and B?
Does anyone have any experience/opinions on the Edelbrock "Power Packages" (cam, lifters, intake, carb etc.)? I faintly recall someone saying some aftermarket cams work better for the SBO than others . . . which are they?
- GoldOlds
- GoldOlds
I personally don't like the E-brock grinds, they are just copies of old generic ones. Slow lazy-*ss ramps. There are a lot of better ones out there, IMO. As for pushrods, again IMO, rocker geometry is often overlooked. The best thing to do is assemble the engine using whatever valve train you decide on, and then get an adjustable pushrod. Use it to determine the proper length, then measure it and order 16 of them. Of course, this assumes the valve stem heights are all the same. Check this, http://www.cranecams.com/?show=faq&id=6
88hurstolds
January 20th, 2020 11:39 AM
442mark
June 10th, 2015 03:24 AM
